recently i saw a catch can made by a well known Sydney fabricator (page 19 of latest HPI magazine). what made it interesting was that it had a line from each rocker cover fitting to the can (connected where the hose joins the rocker covers in stock configuration) as opposed to the normal single line from both rocker covers.
i've heard arguments that a single line from both rocker covers is too small in volume for the fumes being evacuated. the same argument suggested that catch cans had to be of a certain volume for the same reason, although the requirement to retain oil and a filter medium will obviously play some part in overall size. interestingly the Nismo one is about the size of a coke can but drains into the turbo oil drain, and draws from the rocker covers via one line.
based on the number of set ups using a single line to draw from both rocker covers there doesn't seem to be a problem with this approach, and the one in HPI is overkill. does anyone know differently?
cheers
Hey these i would have taken pics of mine but mine is set up like (looking from front of car) right hand rocker cover > to catch can. 2nd line from the intake line to catch can. i'll try post pics later. :whistling:
Just for interest sakes, anyone know what size 90deg fittings (Earls, aeroquip ectr) one can use on the breather holes to do it in braided/aluminum fittings? I presume RB25 and 26 have the same OD vent pipes?
Also are most of you guys keeping the PCV valve and hose in place? or do you just yank it out and plug it?
    • when does it run badly; hot/cold/both, idle/part throttle/full throttle what computer is running it and what data can you get from it?
    • Perhaps, and it's deceptively similar. I was yesterday days old when I first heard anyone mention that the default guards have exactly XXXmm space. No more "is 8.5+37 going to be flush/fit, or will it poke? how much? 9.5 +16.9?" etc. Can just do maths and subtract from 100 - Shit, Wheels should have this measurement stamped on them. "This wheel extends 74mm from the hub in one direction and 57mm in the other" This is a far better system than offset, inches, and backspacing.
    • Hi guys, I know I lt could be a range of issues although when driving my gtr its starts sputtering and stalling feels like maybe an inter cooler pipe loose or so but that's not the case. recently had a comp check with 165psi across all 6 give or take a few psi. a mate was saying maybe IAC valve  could anyone point me in the direction of where to go from next I was thinking coils / plugs.   its due for an upgrade so I'm going to r35 coils. In the mean time I'm Just wanting to get it running alright    cheers
    • I don't know....but I can't see how they would be. Different shape chassis and bumper means it is unlikely the reo is interchangeable. Doesn't mean it would be impossible to modify it to fit of course
    • They're supposed to not be compatible.
