you need one of those GTR 'strawberry face' body kit for V35... people in USA has started to fit them on their G35s
The Japanese word for "strawberry" sounds pretty much like the word "fifteen", hence cars with S15 nosecones conversions being called "strawberry faces".
It's not a generic term for a front end change. :)
spotted vandit coming out of sunny park this morning, car looks hot we should have a photoshoot together one of these days vish!
Hey John , i didnt see you sorry !.. yeah im up for it anytime let me know a couple of days ahead its pretty dirty at the moment just got it bk from workshop
P.S are you comming on the bushfire appeal cruise?
I think thats the only other lakeshore blue one I've seen in Syd. Asian guy driver. He bought it from E & M Unique. I think I saw him heading that way myself. I have the other lakeshore blue coupe.
Who's in the Lakeshore Coupe I saw on Carlisle St this morning?
    • I have one and it was at ~43.5PSI.
    • Put a pressure gauge on the fuel rail.
    • I've uploaded logs / the current map to Gdrive if anyone has any ideas. https://drive.google.com/drive/folders/1FPnr22Z-EilG7tYdHSi0Qb07P2jfFLKV?usp=sharing
    • I'm running a Haltech Platinum Pro with the stock map for the RB20DET + tweaks for my build. When I started it this morning, the IAT was at 32F/0C (Outside temp was ~42F) and the AFRs went off the scale for my AEM gauge. I let it run for ~30 seconds then turned it off. I then did a smoke test, by hooking into a vacuum line directly behind the throttle body, and confirmed there was no leaks ( i let the smoke tester run for ~5 minutes / confirmed it was generating smoke before hand ). I then started the car again, after fixing a power steering leak.... and it seemed to be happy for ~30 seconds (was at ~11/12), but then seemingly shot back up to ~18 again. I then let the car run for a few minutes, thinking this was just cold start related, but the AFRs never came back down. I didn't let the car fully warm up, so maybe this makes sense, but I'm not sure what to do? The AFRs, when I last ran it, were normal, but because of personal reasons I haven't been able to break in the car. It was rebuilt last year. Engine / Mod list: Supertec pistons Spool rods Kelford 270 cams and Springs Stock crank Deatschwerks 900cc injectors Walbro 255 (Wired directly to the battery relocated in the trunk) NKG Audi R8 Coil packs + Conversion Harnesses from Wiring Specialties Holset HY35 turbo Haltech Platinum Pro ECU Haltech boost controller (wired in for high boost RB25 Neo transmission + needed bits for the speedo to work
