Spotted a brunette chick driving 2003 silver coupe, driving from gateway and turning on to lytton road....i think number plates were 371 KVG but i doubt its anyone on here.
also spotted another brunette chick driving silver sedan and went into metroplex area....again, doubt anyone on here
Eye for the ladies i see :D
I live around the lytton road area, but I own a black coupe.
Have never seen you, Luke. I'm always driving around there for work.
Also saw a silver 2004-5 silver coupe parked at Carindale shopping centre with 896 JCR number plate...
And parked in front of a dude at Allingham St in Kuraby with a silver coupe. No offense to who owns this one but the white rims on the silver coupe didnt look nice.
Not quite a V, but saw a black Kawasaki 1100.............UNDERCOVER POLICE MOTORBIKE!!!!!!!!!!!!!!!!!!!!!
I didn't know they had any undercover police bikes.....only knew it was a police bike because it had pulled someone over!!!
You don't own a silver sedan do you? I've seen one getting around lytton and tingalpa a couple times.
Also, been seeing a coupe getting around the city with custom plates ALL DAY
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
    • I'm mark from Idaho.
