Gold Coast spottings....
25/05/11 white coupe, 10.45am, near Bermuda St/Christine Ave, personal plates RI**5
4/6/11 silver coupe, heading south on pacific hwy, before Logan Road exit, plates something to the effect of MW***3
9/6/11 silver coupe, heading south on gold coast hwy in surfers paradise, 810pm....didnt get any other info, saw it last minute :(
earlier that day, saw at 1.30pm, marina mirage area, silver coupe, with rear bar damage :O
spotted "WPN35V" at eastern creek sunday night , sounded nice and mean , thumbsup.gif,
got some ok footage of it on the skidpan
Ahhh nice to know some 1 seen me at the skidpan thanks for the compliments :) .
Where was your v35 @? i Asume thats your 1 on your display? Nice btw
spotted a black 300gt sedan going over the harbour bridge today with a blonde girl driving it. the sedans look awesome in black!!
if the girl is on here, stop chewing your nails lol
Edited by zei20l
Spotted this V35 Ex GREDDY TRUST Showcar from Japan (which is for sale BTW, see CarPoint.com.au) minus the rear bar on the Pacific Motorway heading north towards Brisbane around 7am.
Spotted... :-)
Had to freshen the paint on my rear valance.
Only just caught this, so apologies to all that wave - now understand.
    • It's (the TPS) buzzing? Or something else is buzzing in response? Remove the IACV from the plenum. Block the hole into the plenum with your hand. Get someone to start the car. Let some air is. Do the revs flare up? This is checking that the path into the plenum is clean. After that, is the air hose leading to the IACV fuly clear? After that, either you didn't clean it thoroughly enough to allow the valve to move, or it is broken.
    • Just a follow-up on this topic. From what I can tell so far the rusty residue on the engine block might be unrelated to a coolant leak or maybe just older than anticipated. After driving it from the winter garage to my friend's garage I could not see any new traces of coolant leaking there, but I will test this properly once I was able to fully warm up the car and drive it for a bit. I think I can agree that the whole porous engine block stuff is kind of nonsense, but there is just a silly amount of true, false and half-true information on anything Skyline-related on the internet.
    • hrmmm , not mine , easter plans to pull engine not happening
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
