hey all
Blitz SUS Power Pod Filter and Adapter , Came off my 180sx SR20 DET, Very good Condition
$110 Posted to you
Type X 3 Piece Genuine Nissan Tailights set
$650
Genuine Trust/Grex Oil Cooler Kit + Oil Filter Relocation w/Inline thermostat to suit 180sx/S13 SR20DET
$550 Posted to you
got a good condition working Z32 airflow meter with plug and loom
$280 posted to you
HKS SSQV bov with adapter came off s14 but had it on my sr20 180
$200 posted to you with adapter and bracket, sounds awesome
Genuine Nissan RPS13 Carbon Fibre Rear Stickon TYPE X Brand New In BOX
$250 Posted
S14 SR20DET Manual Conversion
All bolts, pedal box, standard clutch, tailshaft, wiring etc etc ...
EveryThing u need for the Conversion
$1350
S13/180sx CA18DET Manual Conversion
$1150
