Evo Wagon Vs R35
m3gtr
 Share
Heres a great little video of a stock evo wagon trying to keep up with an R35 at FSW.
I thought the evo did a great job trying to keep up although there was plenty of traffic. Some of the "traffic" looked pretty nice as well.
The Evo was awesome. Although the tyres weren't too happy after a couple of laps.
My god those GTR's were phenomenal along the straight- "bye bye!!"
Edited by R338OY
when it got onto the main straight and I saw just take off down the track, it was seriously a "holy shit" moment...............
i was surprised when the 350 zed just booked it down the straight past the evo and then WHAM, the evo dived right back in under brakes.
It was really keeping up through the corners but got minced down the straights...
Meh, small displacement. Give it 1000cc's more and it'll be another story.
yeah it just need another litre of displacement for the main straight.
yeah the evos are just too good at this corner stuff.......ridiculous I say.
All this AWD Japanese trickery is making me dizzy.
What surprised me the most is that the Evo wagon was able to "stay in touch" even though some would argue it was because of traffic.
I have to admit, the evo driver was working hard to keep up. No doubt the GTR would romp away with a similar effort. Still...if i saw that 35 id book the crap out of it to try and keep up. :(:P
cheers for the viewing pleasure!
awesome! loved the white 34R and the evo was pretty awesome too! for stock it pushed it hard! and cornered even harder! me thinks the GTR was puppieing it a little!
on the whole a great little vid!
Yeah, i agree. You can tell that the GTR slowed down to let the Evo catch up. Looked at how the GTR just pulled away from the Evo on the straight until it was out of sight, and when the Evo reaches the corner at the end of the straight - the GTR was right there. WTF??? Also, the way that Evo passed the 34 GTR and other cars was a bit too easy in my opinion. Either the Evo driver was very good, or the other drivers were pretty crap. I think this whole video of the GTR and Evo is just a set up.
good vid, i didnt know they had an evo wagon.... good driving tho :laugh: imagine a "wagon" keeping up with a R35 GTR :)
ahah, thats no ordinary "wagon". its the first evo in wagon form to come out of japan. Its almost exactly the same as the evo 9 but can carry 4 adults, the dogs and golf bags in the boot.. and almost no extra weight has been added to the chassis. i liiike velly maaach.
 Share
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on.
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
