Guest RedLineGTR
idle and at 2000 is about right...the 6000rpm on pressure can rise upto bout 5-6 cant see the marks properly..but for 6000 is maybe another 1kg or 2 more than 4kg...oh well the only problems with pressure would be if you are using a high rating oil like 10w-60w my pressure jumped about 3kg on each spec on idle it was about 3kg. The stock gauges can be sometimes faultu too.
  • 8 months later...
sorry to bring this old tread back but i saves me makeing a new one.. i have a R32 and at idle the gauge will sit at just under 4 and after it warms up it sits just under 2. then after about 10mins or so of driving when stopped again the gauge sits about 3mm from the 0 mark and on the highway it sits just over 2??? i'm using castrol magnatec 15w-40. could this just be a dead sender or gauge the car doesn't seem to drive and different.
seems to vary a bit between models. and it's unusual to hear about a motor being damaged by lack of oil pressure - unless of course it's being used on a track and suffers from starvation under hard braking or something.
Mine will get pretty close to 0 at idle, with a thin oil like 5W-40. I tried some thicker synth oil and it held pressure a touch better but revability and cold start were affected. Now that it's coming back into winter again i put 5W-40 back, and I reckon thin oil's the go in any case.
My unprofessional opinion is not to worry about it, just work out what's normal for your car and if it does anything different THEN worry. :)
i'll get a oil pressure gauge after my cooler install and see what the go is.. the car has 160,000 kms on it and has been serviced every 5,000kms ( that what the previous owner said, i hope ) and the head is only 60,000kms old. could it be a oil pump problem?
I got my '93 R33 turb serviced recently and since I got it back the stock oil pressure guage doesn't seem to be working. More specifically, it is sitting on 0 all the time.
I can't think of anything that they may have done that would have damaged it but surely I'm not driving around on 0 kg/cm2 oil pressure. The car is running fine.
Before the service the oil pressure guage behaved normally.
1-2kg for idle
4-5kg for boosting
Any ideas on what I should look at to fix it? (I have checked connections into the guage). Is there a sensor they could have knocked or something like that ?
Thanks.
Make sure they haven't disconnected the sender connection on the oil filter block, under the intake manifold.
Mine goes off the dial when cold and drops to 2 at idle when fully warmed up and will go over 6 on the track at full noise.
It all depends on how many kays the engine has done and what your oil level is.
I let my oil level get down too low and it dropped to those low pressures, then a big end bearing ran. The bearings were old tho.
  • 4 weeks later...
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
