10pm today sitting at the lights when a black VE SS tinted windows blacker than black :P , lines up side by side with me ready to rumble revs his engine. from me no response so he revs again but a little bit higher in the rev range still no reponse from me. i can tell he wants to race me bad, trying to get me to race him. but guess what? i saw all the extra antennas on his back window. bloody cop! now that's entrapment! :(
that is just wrong!!!!! :/
has this happen to anyone else here as well?
  • Replies 70
Should have put your window down and told him SAU VIC have drag days for that kind of thing!!
I always go extra slow from the lights if someone is trying to make me drag them/similiar, so noone can get confused about whether I was racing them or not..
sad times we live in! good on ya for having the wit to realise and not give in! even if it wasnt a cop im sure u'd have puppied it off the lights and let that common whore know that racing aint for the streets. u deserve to own a 34 R if u aint draggin!
good work
what a punk.....Should have reved a bit, waited till he took off, pull over to the side then dialled 000 and reported him :(
"excuse me officer, sorry to bother you when your stuffing donuts in your mouth, but your collegue is street racing and is a major threat to public safety"
10pm today sitting at the lights when a black VE SS tinted windows blacker than black :P , lines up side by side with me ready to rumble revs his engine. from me no response so he revs again but a little bit higher in the rev range still no reponse from me. i can tell he wants to race me bad, trying to get me to race him. but guess what? i saw all the extra antennas on his back window. bloody cop! now that's entrapment! :)
that is just wrong!!!!! :)
If your car is the one in your avartar I'm amazed he didn'y pull you over for a "random" breath test anyway.
i thought unmarked police cars cant/dont have window tint? All the ones ive seen have no tint and its easy to spot the lights sitting on the parcel shelf..
Nah, they have such a dark tint you cant see through them at all. Unless you shine a torch on the window at night.
Dirty MUTHA F**king cops.
Cheapest / lowest way to entrap someone minding their own bussiness. Bastards! And I don't think I have come across any REAL Hoon who actualy revs their engine.
They usual just wait at the lights.
Cops think their being a hoon and can suck us in but when they rev the car is just making it more obvious.
Go on ya for not giving in!
I don't drag at the lights. Its just pointless and reckless.
BTW if ya did drag him, he would have shit himself, your car would absolutly destroy it.
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
