Doing Up A Stock R33 Gtst
That is self help. Encouraging others to spend more than me, makes my spending relatively less ridiculous.
By soviet_merlin · Posted
Oof, I don't think you should add it up like that! It sounds much better at $21 per issue. I don't see any problem there if you enjoy the process and the result. I really like the magazine side of it with all the little tidbits and facts. Also, if anything, these forums are all about spending unreasonable amounts of money on hobbys. I wouldn't call it a self-help group because people generally suggest to spend more -
I put another 2 layers of putty and still getting pinholes. Think i might either try the filler first then putty or just leave the little specs of guidecoat as is and get primer to fill it in. I think i misread understood what you said above when you said my glazing putty wasnt enough for the size of the area. I thought you meant 1 coat and i needed to. But i think what you meant was that I needed filler first? I also went a bit too far out the repair area as my spreader is a bit large.
You do sorta. In my instance they were little specs and I didn't even think they'd be pin holes but it all makes sense now. Huge learnings there!
Ah ok that makes sense and it's where i think i went wrong because before when i put filler then putty, i didn't have this issue and now i do because i only put 1 coat of putty. Thanks for that heaps man, it's a good way to put it! With my putty I'm using the dolphin glaze which i just saw it says finishing putty lol. I didnt put filler cause it was a shallow area but i see what you're saying. Also I'm an idiot, i just realised that while i put new putty there are pinholes! I probably saw it before and ignored it for whatever reason. I think because i thought putty is used to fill pin holes that itself wont make pinholes but that's incorrect of course. I feel silly now haha. ok I think I know what to do next. Thanks man!
