Hi all, I have a 1997 r33 GTST, I have had it for a year now its all stock. I have only put in a turbo timer, installed a indash dvd player, front splits + back and amp. Wondering what things i should change/mod to do? I was thinking about buying rims + wheels, its currently got the stock 16" Nissan RIMS but not sure what type/size or the cost of good rims would be??
A friend has suggested an exhaust.
Anyone else have any suggestions? OR should I just keep it as is, stock??
Edited by sumguy
https://www.sau.com.au/forums/topic/210303-doing-up-a-stock-r33-gtst/
If you want performace i would go
Pod filter
Exhaust turbo back
Intercooler
Fuel pump
Spltfire coil packs if needed (if oem ones play up may be able to tape or glue them for awhile)
Bleed valve
Injectors & AFM (Air Flow Metre) If these are needed with the power your chasing
Turbo
Computer
Clutch damm clutches i made the mistake of getin one earlier in the process and then got more power then my clutch was rated at :(
Looks wise
Tinted windows
Rims
Bodykit to suit the width of your rims
Then lower it i say this so you know how much height your kit will need to clear the ground / speed bumps i also had to lower my exhaust to fit the kit
Thats a good start i reakon how far do you wana go with the car? Just a warning once you start modding most people cant stop it gets very addictive and you end up spending alot more money then you initially intend haha.
Forgot to mention good size alot of people go with rims on 33's are 235 wide on front and 255 wide on rear but you also wana get a rim that has the rite offset (how far a rim sits in or out from the gaurd) i cant help ya much their but a tyre/rim place should put you on the rite track
The first thing I did was fit an exhaust...
Then I lowered it
Tinted the Windows
Bought wheels
Finished rest of exhaust (cat + dump)
Then FMIC boost controller + Power FC
Brake upgrade
Then Engine RB30 convesrsion haha.
By the sounds of things you dont want to modify the car for performance since you've already spent money on things like a DVD player and amp. So my suggestion would probably be to start with lowering and wheels... 8.5" front with a +30 offset and 9.5" rear with a +35 offset would be nice and agressive. Anything lower than that would be pretty hard to fit under stock GTST guards...
Edited by MintR33
I bought a stockish s1 33. It only had a aftermarket head unit, cat back exhaust and crappy rear speakers which werent mounted.
In order I've done:
- apexi pod
- 6x9's in the rear shelf
- drift bov
- cheapy boost guage
- the $22 boost controller (works a bloody charm!!)
- silicon hoses
- tyres! I've replaced all tyres and I only bought it a month ago.
Next things Im considering (in no particular order):
- FMIC
- dump and front pipe
- hi-flow cat
- body kit
- 18" wheels
Unfortunately I need to stick to cheap mods so the bottom 2 will have to wait. I'd appreciate any suggestions as well, without hi-jacking :P
Pod filter
Exhaust turbo back
Intercooler
Fuel pump
Bleed valve
Turbo
Computer
This is really good advice iLec, i was looking for something like this that shows a sensible order of power mods.
what are the brands i should look at for exhausts? How much will they cost including installation?? Any pics around I can see it? I want mods/changes to the car especially for looks rather than power.
Ad you guys mentioned intercooler, this car has already got a stock intercooler, I'd rather not spend anymore money if its already got one fitted.
Just got my car serviced few days ago, also replaced fuel filter and air filter so those don't need replacing
Edited by sumguy
Dont bother with an intercooler until you plan on running more boost... It won't do anything except slightly increase turbo lag. I wouldnt even bother with a pod filter either.
I put intercooler cuz its good to get those "support mods" before you go all out with another turbo, power fc yada yada yada when my intercooler was installed i noticed lower temps specially on hot days and there was very minimal lag and that was with a hybrid intercooler. That just my experiece though.
+1
my R34 already had a hks pod,
I did exhaust, then intercooler first. If anything the turbo boosted harder due to the exhaust and the i/c kept temps low and overall drivability was better.
Then I did Boost controller and Power FC and nismo fuel pump.
As this is in the cosmetic section,
The first thing I'd do looks wise is a good set of 18" rims with decent tyre and offset.
Then a bodykit to flow with the overall look of the car
hey mate, where u located?
i have a 3" cat back exhuast with cannon and 5" tip im wanting to sell....used for 2 days.....full stainless steel....polished and all....looks schmick! awesome note aswell.....im selling for less than half of what they retail for new....
if ur interested....let me know...either pm me or something....can organise something....if ur kinda local..or not too far from me....let me know!
Good day mate^^, I'm pretty much a car dummy ~_~.. Let me describe my beloved car a bit. I have a R33 Gts-t series 2, what has been modified was Pod filter (I was using Apexi filter and had it changed to 3A racing pod filter when I read the magazine that 3A racing pod filter was rated 1st in flow and 2nd in filtration among the top 10 brands), Kakkimoto Cat back exhaust (which look pretty old and not sure if I need to change for a new one), R34 rims.
What happen is whenever I push down the gas when I shift to 1st gear, the car sort of lagging for a few seconds as in you feel the car does not really move, I'm not sure if I can describe this as "turbo lag" or would you mind to describe "turbo lag" a fair bit? Does all turbocharged car has the same problem? My friend recommended me to get a boost controller but I don't really know if I really need one.
By reading some of the thread posted by other mates, I don't know what are the correct order if I need to do some modification on my car. I know ECU, fuel pump, FMIC, exhaust system are equally important but which one should come first with minimal budget. Apparently I can't fork out a few grand now have them all changed but I hope to do bit by bit. Umm, let's say now I have a FMIC installed on my car and will it make any difference on the power on the stock turbo?
All suggestions are welcome and very much appreciated!!
When i got mine, first thing was change brake pads, fit exhaust rims and FMIC, then turned up the boost a little, then drove it like that for 3 years, 200kw and it was a good fun car and didnt cost heaps to do
please explain how you made 200kw with an exhaust and fmic? how much is a "little" boost?
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
