Garrett Gt2860r -5, Gt2860r -7, Gt3071r Turbos
Hi guys,
recently i managed to get a good deal with a supplier in USA to get good prices with Garrett turbos. For now, i have confirmed deals for Garrett GT2860 - 5 and Garrett GT2860 - 7 turbos for RB26DETT engines.
Price for 2 X GT2860R - 5 will be AUD$2,150 delivered
Price for 2 X GT2860R - 7 will be AUD$2,150 delivered
Price for 1 X GT3071R (T3 Flange) will be AUD$1,500 delivered
Delivery time will be 6 - 12 days after payment has been cleared
Supplier Details : PSI Parts
159 Ivyhurst rd
Amherst,NY,14226
Prices for just a single turbos or turbos for other engines, please PM me and i will contact the supplier.
Duration of the group buy will be for 2 months. Ending on 15th May. After that, depending on the demand, we may organize another buy again.
Please note, all money transactions will go directly to the supplier, i am not making any extra money through this.
Interested parties please PM me for details of payment and delivery.
Items comes with 12 months Garrett warranty on manufacturing defects.
Admins and Mods, please let me know if there is any other information you require from me for this group buy to proceed according to SAU forum rules.
Thank you.
  • Replies 88
hey there
this looks awesome, as im looking at getting turbos for my gtr
so if i deposit modey now i get them in 6-12 days or do i get them in may??
do they come with any type of warranty etc??
hey there
Hey,
If you pay now, you will get them after 6 - 12 days once payment is clear.
I will check with the supplier regarding the garrett warranty.
do these come with anything else, other than just the turbos
as, im aware the HKS kits come with oil lines, gaskets etc...
but they are more pricey
Unfortunately they just come with the turbos just the same if you buy them from hi octane racing or Croydon racing.
Yes the HKS GTSS kits come with the oil lines etc.
Got a reply from the supplier.
The turbo comes with a 12 month warranty. It can be claimed through the Australian Garrett distributors or sent back to the states either way.
BlitzR33 - Sorry you have to get the gaskets yourself. However, these turbos will bolt on to the standard ones.
I am tossing up between the gt3071r and a GCG highflow. My question is as i can not find it elsewhere what is needed to bolt the gt3071r to an rb25, is it just modified oil and water lines or the whole hog meaning custom dump pipe and intake side as well.
Guest Rotary20B
I'm in the same position, was going to get a GCG high flow but now leaning this way
Guys, if i'm not wrong, the GT3071r will produced much more power than the GCG highflow. It is similiar size to the HKS 2835 but i'm not sure on that. But it is cheaper than the high flow which GCG charges $1,950.
If you want, go to the Garrett webpage and they'll show the sizes of the turbo.
    • Come to Eastwood, you'll get plenty of that 馃ぃ
    • Oof, I will forevermore have those shredded gears in mind whenever someone talks about showing mechanical sympathy towards their car. Thanks for the photos, fascinating stuff!
    • Curious to see how the SpeedTek stuff holds up
    • The holdups last year were drivetrain related. I had the car out right after getting the bearing issue resolved. Third launch and the car didn't move after releasing the clutch. It had sheared all the engagement teeth off the 1st gear.    Thankfully no other damage was done. I set an aftermarket gear beside an OEM gear and found that the engagement teeth on the OEM gear were much larger and better supported. Looking through my bin of spare transmission gears I found that there are two types of tooth on the OEM first gears - the larger tooth and the smaller tooth. It looks like most aftermarket gearset manufacturers base their design on the smaller tooth. OEM large tooth left - Speedtek, OS Giken, etc or OEM small tooth right Decided to give that larger engagement tooth a try. Pressed the ring off an OEM gear and sent it to a transmission manufacturer here in the States. They did their "faceplating" operation with my synchro ring on the Speedtek gear.   I reassembled it, took it back to the track and promptly destroyed the gear itself.  I'll rebuild this and use it as a spare - thankfully just first gear and the countershaft are damaged beyond repair. Definitely disheartening but my welded on engagement tooth ring held up!  Moved to Speedtek's dog engagement design as the gears appear to be much stronger. So far they have taken much more abuse at the track. Also scored a Stillway lockout from the Netherands for super cheap. It's for some other RB transmission so it took a bit of fabrication to fit but honestly a very easy job. I also had to heavily modify the gates as they were very different.   Then for some reason at the last test and tune a silicon coupler below the throttle blew off and took out the radiator and fan. Thankfully it was in the burnout box and not down track. This car is really beating me up - I still haven't made a pass in it. Ran it through the gears many times on the street but it keeps biting me at the track.  Currently in the process of replacing the radiator and remaking the throttle pipe to remove the coupler and use a cast 90 and a vband. I WILL get this thing down the track...
    • Covers most of the above points really. There's a few exceptions but most just see driving as an irritating but necessary task they must complete if they want to get anywhere on time. Also see it as a good time to show their awesome multi-tasking abilities on their mobile and/or doing their makeup.
