yes, there is one combo that works time and time again for GTRs running small-ish low mount turbos.
Nismo fuel pump with Sard 700cc injectors. the nismo pump flows 276 litres per hour which is enough to support 6 X 760 cc injectors, so it's a good match for the sard 700s.
plus it fits straight in and has proven to be reliable. the money you save with cheap pumps is easily wasted in time taken to fit them and potential reliability issues.
don't forget to buy new injector 0-rings from nissan for the injectors.
The 044 is ok but thats meant to be an external pump...the internal 040 is a good pump but the filter design is crap...and recently i have seen a few fail due to that...mine is on its way out too...so stay away from the 040...
Are Bosch 044 fuel pumps reali that bad???
Nismo fuel pump - around $400 ++
Bosch 044 pump - around $200....
Big difference....
no, I've seen the Nismo for $300 - $320 and I find it by far a more superior pump than the bosche, and flows more at higher pressure.
Oh, and not a sigle bit of stuffing around like the crap you have to do to the bosche. The NIsmo drops straight in.
Oh, and the Nismo is quieter..... Well worth the $100 more. If you can't afford to spend an extra $100 on a pump, then why do you own a skyline?
anyone have any ideas where i could get a NISMO in the $300 bracket???
Also now when i get the SARD 700cc injectors and a fuel pump... anything else holding it back in this light bolt on upgrades??
