The screw aloows you to adjust hte spring tension. When you are running more bosot pressure you might find it starts to leak in higher rev's so you want to tighten the srping up, however if you are not running as much boost you want to loosen it off to ensure the BOV will be able to open. However they more adjustable nowdays for rice factor to get different sounds.
BOV"s are illegal for the reason being that they vent blow-by into the atmosphere... yes they can be noisey, yes they cause the car to run richer but its stated that they blow un-filtered air/oil into the atmosphere... stupid really, cos last time i checked the exhaust vented to atmo aswell?? But thats all good its only carbon monoxides and what have you, alot worse than the 'ocassional' mist of oil comin from a BOV.
P.s. Don't forget BOV's if they aren't a good design will cause crappy throttle response, and having a atmo BOV means you must re-spool that released amount of air. They have their pluses and minuses.
As YBSLO4 mentioned BOVs are illegal if they vent to atmo, because cranck case gasses must exit the car via the exhaust, Road Traffic Act 1962 (from memory) in SA. These traffic laws are now pretty much consistant australia wide. So they MUST plumb back to be legal - like the stock one.
As for adjusting BOV, tighter will mean it takes more (boost) pressure for the valve to lift. Yes it will make less noise, but the fluttering noise you hear is air reversing through the compressor, slowing the turbo down (increasing lag) and putting strain on the turbine - this isnt too good for obvious reasons.
I adjusted mine by winding it back until the fluttering sound was almost gone. Almost, because if you wind it back too far, you may have the car stall at idle as it doesnt seal properly. Something to have a play with until you are happy.
The only noise testing I know of that a car needs to be roadworthy has to do with the exhaust, this is done with the car at revs, and the EXHAUST is not to exceed 89dBs. This is conducted with the car at specific revs, not changing gear - so I am not sure how any copper gets away with defecting cars for excessive intake noise (how could it exceed 89dB?) or noisey BOV which wouldnt be measured if a car was being tested for compliance with noise regulations - only for atmo BOV or pod that doesnt comply with ADRs.
I have heard of people claiming to be defected for this, and I would love to know exactly what regutation/act it is that they would be in breach of?
    • Speaking of diverting threads, my second ever NISMO purchase…. I think they look pretty classy and just wanted to share 😅   PS: 1st was the oil drain plug 😂
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
