Did the R33 GTS-T's come with a boost restrictor that you can remove to gain a SAFE Factory boost increase like the GTR R32's? The Brass Boost restrictor I think its called..?
If so, remove it and you sould get up to 7 psi...
Yep they come with a solenoid that opens at 4500rpm...When is opens it bleeds enough air to add extra 2-3psi of boost...it feeds back into air intake just after afm so that the air calculation is not stuffed up...From memory stock boost is 5 psi below 4500rpm and jumps to 7or8 psi above 4500rpm...Most people just remove it or permanently short the terminal to ground which holds it open all the time...Its really basic and I dont know why Nissan bothered with it...but anway they did...
I ended up replacing mine with a hydraulic needle control valve (now have EBC)...Its was better than a standard bleed valve because it passed all bled air back into intake...whereas normal bleed valves bleed air to atmosphere and are therefore technically illegal...
Before you do what **RB2530** says, how do you know your car is running just 5 psi of boost ? Do you have an aftermarket boost gauge, or are you just reading off the stock one one the dash ? Cause I hope you know that's not in PSI, but in mmHg. (where 5 mmHg = 'round 9.5 PSI)
Right, I see! You know Jap cars LOL! The more buttons to push the better LOL!
I believe the Stock Boost Gauge reads in -0.7 to +0.7 Bar
i have an aftermarket boost guage.....and its reading less than 5psi
Did you say your car was stock except the new exhaust you put on? Check out to see if the restrictor is still there... Ask you mechanic if your not sure...
which restrictor are you talking about?
Hey WOG BOY!
**RB2530** explains it. I will post a pic to show you where the Solenoid is (But It's From a GTR R32... I Think R33 GTS-T's Might Be Different?) But to give you an idea.
Where it is circled in RED is, I believe is the Boost Solenoid. Inside there is whats called a Brass Boost Restictor, which can be removed to gain a Safe Factory Boost increase of about 2-3psi.
**RB2530** Might have a pic of what the R33 GTS-T one looks like.
    • Haha actually I did join back then under a different email address,  I couldn't re-activate my account so made a new one! I didn't post much anyway so not missing out on much. Amazing to see how the value of the cars and parts has changed over the years, also ACT section appears to be dead now.
    • Thanks... It's in pretty good condition overall, probably due to not being drifted/tuned however being a daily driver has taken its toll. Had 100k on the clock when I got it, up to 180k now. Unfortunately it's not 100% dent free, it's got a small dent on FLH side and broken indicator from where I hit a small kangaroo at high speed. If you look at closely at pic #5 you might spot the dodgy trailer light repair my old man and I rigged up as temporary repair! - It's still there due to a combo of needing the car as daily driver and then too lazy/busy to fix properly. I've a couple of other minor accidents accidents as well but nothing major. One required a new front bar and unfortunately the smash repairer ordered the normal gtst one and not the aero bar. Needed the car back asap so just went with it, regretted ever since.
    • I can't believe that anyone is foolish enough to believe that the base maps are for any other purpose than to drive the car up onto the trailer/truck or gently creep it to the dyno. No matter how good they are, they can never be any better than the factory maps**, and only the foolish trust those on a significantly modified setup. **Yeah, yeah. I know there's also the difference between factory maps being fixed to certain injector sizes and MAP/AFM/VE relationships, and the likely aftermarket ECU base maps being better able to handle the sorts of changes that would render a stock ECU dangerous, like different sized injectors. But let's just ignore that for the moment, because the principle is still the same.
    • I'm shocked, you've owned a Skyline since 2006 and never joined SAU before now! 😮   Welcome, it's much quieter these days than it was in 2006, but lots of very knowledgeable ones lurk around here. I actually think in outage we've forgotten more about Skylines than anyone knows about them today... 😛
    • So it could give us some info. Such as we find out what number they started at, and we know how many of those blocks came before it.
