Ok im confused all.
At first i thought it might of been adjustable cams were out. But i dont think it is that anymore.
So i have great power up till 4 k. I hit 3K and boost comes in strong and then hits 4k and it goes no where!
Even when im running 13psi instead of 9psi it makes no difference in power i have the same effect.
Im thinking its a fuel delivery problem? It feels as if there is not enough fuel after boost has come in to satisfy the amount needed.
I have bought a fuel filter to swap because that one looks old. After that im thinking fuel pump? if it isnt enough pressure.
I have also noticed my fuel economy go to shit! where i was getting 100k to 1/4 of a tank i now only get about 70km.
Could it be a timing issue at all? or a blocked exhaust? thats another thing i was thinking. Any help is appreciated....
mods are:
rb20det
r34 turbo
cooler
r34 fuel pump
running 9psi and 13psi
dump into 3inch all the way
Edited by Drakey
https://www.sau.com.au/forums/topic/210342-loss-of-power-over-4k/
Could you describe the problem? is it spluttering, missing, flatspots??
Youre running the factory ecu? and the factory injectors?
my guess would be the injectors maxing out. have you tried running eg 7psi?
in saying that, it could also be a spark/coil issue - what plugs are u running(gap). have you had a GOOD look at the coils?
I would first turn check out the plugs and coils closely.. inspect the plug tips closely( i think white means the cylinders leaning out, brown is rich and black is oil). if that checks out ok, try putting new plugs in eg NGK .7mm coppers HR7(you would want a colder plug perhaps).
if the tips are ok, then i would suspect it to be ur injectors maxing out.
in saying that, it could also be a collapsed cat.. do the easy ones first as ur problem will most likely be something simple.
it has the tiniest flat sport just passed 4K and then smooth as all the way up just no power!
I dont know about what spark plugs are in, ive only owned the car 4 or 5 weeks. I havent tried 7psi.
The thing that gets me is it was running fine at 14psi up until a couple of weeks ago when it all changed and it was a gradual change also.
hmmm it was running "fine" before. that doesnt necessarily mean the injectors werent maxing out. There could have been a problem before which maybe wasnt as bad as it is now..
anyway, check your plugs. i bet $2 its your plugs. splash out for some new plugs! :blink:
Turn the boost down real low. Like 5psi. If it goes better then you have an idea of the issue. Boost would be fine in this case, it could be 1. Coilpacks 2. Spark plugs 3. Old fuel pump
I'd look into all those anyway. Every one of those issues has made me lose power. The car just gets tired with age and you need to upgrade the fuel and spark components.
Pump- Get a new one, price ranges from $200-$400. Check the DIY threads if you're mechanically minded.
Coilpacks- Get splitfires $5-600 new (SAU trader threads have them) or read the DIY/Maintenance sections and see the coilpack repair section.
Plugs- NGK coppers, 0.8mm, $24 for 6. Do them anyway.
Also make sure your cat isn't collapsed. That can strangle the motor.
G'Luck.
R33 actuator is 5psi.
Are you sure?
I understood that the actuator from an RB25 turbo held 7psi but the standard solenoid was setup to run 5psi below a certain RPM then once it reached that RPM (4,000rpm or whatever it is) it went up to 7psi?
so the soldenoid acts as a restrictor but the actual actuator is 7psi?
Maybe I'm mistaken..
Are you sure?
You can't make the boost go lower than the actuator rating.
The R33 is a 5psi actuator, and there is a factory solenoid that bleeds it so it increases to 7psi at 5,000rpm.
Hey guys,
Plugs changed.... still no good...
Fuel filter changed... still no good.
Does anyone have a pic of a skyline cat... cause it looks like i have got a 3 inch pipe the whole way and that the cat casig is just welded on the outside so it looks like a cat...
Any other ideas guys?
Hey guys,<BR><BR>Plugs changed.... still no good...<BR><BR>Fuel filter changed... still no good.<BR><BR>Does anyone have a pic of a skyline cat... cause it looks like i have got a 3 inch pipe the whole way and that the cat casig is just welded on the outside so it looks like a cat...<BR><BR>Any other ideas guys?
haha so i start my car yesterday.
notice my fuel economy is really good!
so i put my boot into it and hey presto i got all my power back! until i hit likr 6250rpm and then it cuts out again.
So yeh i dont know.. lol im stumped. It might be knocking and causing the computer to go back to limp mode?
Maybe bad fuel has caused it DET. Anyone else got ideas?
My 33 GTST had a real flatspot at 5000rpm and bad fuel economy 250 - 300km's a tank on.
tried an ECU reset helped a bit, then noticed that she was running super rich.
Turned out that my AFM needed replacing. It was working, but not great, it improved after being cleaned internally but not enough. Then new spark plugs as they were fouled from the rich running. Now operating on stock maps, so next stop Power FC.
Try swapping out with an AFM that is definitely working tip top????
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
