Looks good!
I'd like to see how you plumbed up to the factory pump too, I'm collecting all the bits to put swirl pot and couple more 044's in at the moment, not sure whether to go for braid or the push-on hose that earls do!
http://cgi.ebay.com.au/EARLS-10-SUPERSTOCK...=item27ae77bd34
Looks good!
dont use the push on hose for unleaded fuel.
both gates and speed flow say their hose is unsuitable so I would assume Earl's would be the same.
I think they all say that, same with the stainless braided, only one suitable is the teflon and unless I win the lottery I cant see that happening!
what should I use?
We can supply you earls teflon lines at a very reasonable price, email me for a quote.
180or200 - For ideas you might want to see how we connected up the factory lines and used the standard pump as a lift pump.
Link: http://www.skylinesaustralia.com/forums/Ps...g-t242907.html#
Dave - Curious as to why you kept the standard TB? I would have thought you would go have gone the Q45 for that power level. Also keen to see how the brakes hold up on a track day with the wastegate so close to the ABS unit.
your thread doesnt show the actual connecting to the plastic part of the tank though
Sweet engine bay Nytsky!
As quoted previously, turbo dump pipe should be as big as possible. Thats why you see see turbo drag cars just have enough piping to direct it away from where it might melt something and that is it. Bigger = better after the turbo. Obviously on a street car there are physical limitations that you have to work with.
The GT3076 has been pulled off and will be replaced with a GT3582.
The new turbo has the new .70 surge slotted comp cover and .82 housing in single entry.
T3 or T4??
I'm debating whether to go for the Twin Scroll GT3582R T3 0.78 or T3 0.82 or T4 1.06, arghhh the choices!!
Have been in an EVO running a twin scroll 1.06a/r GT3582R, the spool is seriously seriously impressive.... I have a .82a/r GT3076R and I'd honestly not expect to feel too much compromise going to a T4 GT35R.
  • 2 months later...
how is the car going with the new 3582, im just finishing up my 26/30 build with this turbo and would be interested to know if this turbo will give me 550hp at the wheels
oh and how much to get my comp cover slotted cos i would really like to have that 51r spool noise
It has been garaged since Powercruise.
Adding a few bits and pieces.
Unfortunately the noise from the 3582 is nothing like the 3076 i had, even with the surge slot cover. Makes me want a T51R KAI now :blink:
Thats interesting dave, i can play waltzing matilda on my surge ported 35/82. Wonder if the 30 bottom end makes a difference.
Hi Noel,
It does produce a noise, id say half as loud as the 3076.
Was nice to meet you at Superlap on the weekend :)
DOOOOHHHH! I never connected the dots. GRab me by the ear next time mate. would love to have a good yarn with ya. :blink:
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
