I think they all say that, same with the stainless braided, only one suitable is the teflon and unless I win the lottery I cant see that happening!
what should I use?
ended up getting teflon hose and fittings from this guy
http://stores.shop.ebay.com.au/Torques-U-K__W0QQ_armrsZ1
happy with result, back yard special but its ok, main thing is she's nice and rich, not sure if it's safe running 2 bar tho!!!!
how is the car going with the new 3582, im just finishing up my 26/30 build with this turbo and would be interested to know if this turbo will give me 550hp at the wheels
oh and how much to get my comp cover slotted cos i would really like to have that 51r spool noise
if you dont end up with atleast 550hp atw with that combo, your not trying hard enough haha
thats from my evo with a 2.2 stroker and gt35 .63 rear housing..
sounds good then, should be done buy next month and have it down brissy for powercruise, providing all goes well and i can pay for the vipec and redlines oils needed lol
oh and my 3582r has the 1.06 rear
Edited by blockasR32
Nice one Adrian. Your pumps are probably as loud as mine ;)
Does anyone know if i can still retain VCT with Tomei Procams? 270/10.25mm? IN/EX
More to come guys.....stay tuned :sick:
I know you cant on the 33 head dave and i dont think you can on the neo either. dont quote me on that but i am quite sure its the case.
Hmmm i really dont want to lose the VCT.
What is the biggest i can go with the intake cam?
Is say a 270/9.5mm IN 270/10.25mm EX doable?
Or
260/9.5mm IN 270/10.25mm EX doable?
Or
Do i just go the 270/10.25mm IN/EX then get one of those Greddy adjustable inlet cam gears?
I need some options.
    • If you are fine with China turbos, Maxpeedingrods makes a bolt on turbo. Ive had mine for two summers now and it seems to be holding up ok.
    • Howdy all Im in a little predicament and wondering what everyone’s thoughts are? I’ve had my long block rebuilt and am in the market for a turbo due to my old one having metal shavings from crank bearings (cause of rebuild) go throughout the turbos oil lines and there wheel has a little play. I’m not really aiming for any power, just trying to keep it as oem as possible, but I can’t find a turbo that’s built for the stock ecu or find something that would be a standard replacement. Anyone have any ideas or suggestions
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
