I thought the stock VCT was just a solenoid on the left which interacts with the head, didn't think it did anything with the cam gear. I also thought it was on the exhaust cam only, but could be completely wrong.
Reason I ask is there are full adjustable (change based on rpm) cam gears that look similar to what is on his intake cam, they are around $3000 though from what I've seen, fairly complex piece of hardware.
You are now never allowed to give advice on this forum again...
  • 4 weeks later...
Exhaust is finished, work of art! I bought 2 cats, one 5inch 400cpi Euro 4 and one 5inch 100cpi.
Still the same clutch but bought an alloy flywheel from the states.
Should have the car home very soon, just some minor things to tidy up.
Pic of the mid section.
ive always been a fan of the lobster back bends as i appreciate the workmanship involved - nothing beats it!
is there a performance gain from this though as 1 would think that a mendrel bend would flow better as it is a smooth curved edge & there is no weld edge on the inside of the pipe - i guess the difference is within a bees d1ck anyway lol
Edited by Marko R1
past the cat it makes no difference, especially at 4 inches!
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
