I test every batch of fuel and United is always between E85 and E90. I did get an E93 once but these changes seem minor to the tune. If I used Caltex it would run a bit richer.
how do you test?
i've only ever seen E80 - E83 with my GM Ethanol content sensor.... never seen United E85 higher (did see E84 briefly once but settled after 30secs or so at E83)
Eflex for me when i used it was always bang on E70 - i made 15rwkw more on E85.
  • 6 months later...
Making use of the United servo up the road from my place. Paying $1.14L which isn't bad.
Back on the road again after a head gasket change and new gearbox. Engine feels stronger off boost so I think comp is slightly up a bit after the new gasket went in.
Went for a cruise on friday night with some of the boys and felt great :)
Back on the dyno in a couple of weeks to test out the new gasket with more boost, see where this turbo runs out of puff.
Woo hoo! Cant wait....
Wow I've been beltng through this build in the last 2-3 days like a book you just can't put down. This story has it all, highs, lows, external gates :P
Seriously man what an awesome car you've built, hats off to you. Hands down the most insane GTST I have ever seen, I love it. For god's sake just make sure that now you just concentrate on getting your money's worth out of it by having fun driving it! ;)
Thanks Nick! Driving it is always fun. Definitely need to do more of it :yes:
Maybe you can take me for a run without breaking it this time :P AND maybe ill try do the same lolz
Oh no. What did they do you for? :( I hope they didn't smmash you too badly, but with that huge mofo hanging off the hotside of the engine..... hmm haha
This is why they shouldn't be driven on long weekends. They're everywhere.
The problem is I'm 100% sure Dave wasn't doing anything stupid or hooning if you will
The fact it's an import is the only reason
The amount of smoke billowing bald tyre no brake light cars out there on the road that don't get stopped is frankly dangerous
Dave next eastern creek track day you should come an unleash the beast
I told him my car would produce less emissions than his patrol car :) Thing is most coppers have no idea what they are looking at, so they just issue you with a DECC notice.
Could have been 100 times worse though. I got off fairly lightly considering he flat out laughed at me when I popped the bonnet lol
an older head will serve you better dave. There are times I just dont drive the chair for this very reason.
Mind you putting around in my tweed hat raises their eyebrows a bit. I have had them do a ubolt to hunt me down then just shake their head and drive off when they see the old foge in the tweed cap driving.
The walking stick is my second line of defence, if the cap doesnt swing it the cane usually does.
Growing old isnt all shit and shrapnel.
  • Like 1
    • That's the thing. Especially at idle, changing the cam angle by that much could be spewing more fuel out the exhaust courtesy of everything happening that bit later. More fuel also means more air (if the fuel didn't burn, then neither did the O2) and so the O2 sensors can start to tell interesting but misleading stories. And the specifics of what is happening could easily be affected by everything else you changed as well. And it could be dynamic, where a few revs more or less could somewhat change how the engine is breathing.
    • Good idea on the temp probe. The mv readings of the O2 sensors are very similar to one another, as is the injector pw. I went through logs in the past to see if there was a discrepancy and there is. Because they alternate up and down as narrowbands do.. they do often 'switch' as to which one is more. They were never 20%+ (more like 1-2%) so it's possible the difference between 20 and 15-17% is a similar discrepancy to 2.0% and 1.7% which I wouldn't have really noticed in the past. We did think about spacing the strut brace. Unfortunately the ~20mm that the GTR brace is lower than the GTT brace is effectively what you need to clear the vents. Moving it up would make it very uncomfortable, but it's plausible that 10mm is a unhappy medium between both hard places... The good news is.. using MR HAMMER it was actually pretty easy to bend back the bent bits to make sure the guard and headlight/new headlight tabs line up right. Yes, we used a R34 GTR guard to make sure the bolt holes all lined up with a known straight guard. As above, you can see the side skirt and the GTR guard are not meant to play together, but everyone seems to think this is a simple fix to the point where nobody who has had these talk to one another mentions how... ...so I'll just assume they know how to fix it when it comes to paint jail time again. Whoever they are. Nobody returns my calls. There's so much changed with regard to the ECU and the car.. that the next step really is to connect the scanner and attempt to drive the thing. It'll be pretty clear pretty fast how in or out everything actually is...
    • That's nasty! I think there is perhaps an inherent problem is using elastomers in such environments. The whole thing can and will get quite hot, and elastomers are not famous for their temperature resistance. On top of that, if the components are cast rubber or urethane and so on, there might be QA/QC problems with bubbles or voids in the material that could critically change their performance. They might just tear apart after being squished (presuming that any elastomers are used in compression rather than tension, I'm thinking that you squeeze one with a void in it and it tears the wall of the void to the outer edge of block, then the next time it extends or otherwise twists, it just gives up). This is all purely hypothetical, but it makes me wonder if the things that they have put into it to make it nice to use/live with are perhaps going to cause occasional failures like this. I wouldn't be getting up in arms over it, unless there are many repeats. I have personally ruined an Xtreme clutch - just an HD thing. I can't remember if it was still behind the 20 or was after the 25 went in. But it inverted some of the retaining spring/clip things around the outside. No-one could explain it. It wasn't thrashed, there wasn't heaps of torque being put through it, and there were no obvious problems other than the above. They were quite concerned by the event so they replaced it even though it was a few years old, which was very nice of them. As far as I am concerned, these things happen with clutches.
    • Any damage to the box/input shaft?
    • Hey there Mate , I just got my local guy to install it Waterhouse Performance, Penrith (specialise Nissan/Datsun and other performance cars) , you can do it yourself if you like , AMS has instructions on their website.  Cheers Pac
