The GT3076R when I looked for and chose one looked like it'd be best used at around 22psi on a built RB25DET so there isn't a huge amount of use for it over that. Its a nice not overly laggy turbo on an RB25 so with 22psi there should be a huge fat power delivery, it'll be wicked for a road car that can do drag and track. Just because the engine CAN make 100hp/cyl doesn't mean you are obliged to - it just adds one part of the equation to get what you want out of it.
Highest power pump gas/power per litre car I've been in was a still 2litre EVO 2 running a .82a/r GT3582R running ~2bar of boost putting down just under 500whp (125whp/cyl), way faster than any daily driveable 4cyl street car should be.
Yeah i agree with you about having a drivable car and not necessarily having to run at the 100hp per cylinder mark. I figure most car enthusiests that do get to own a car that is stupidly over powered proably in the end gets rid of it and trades down to something with a more practical power range.
Personally i hate big turbo cars. Lag, followed by the lack of traction that follows. A problem caused by running a turbo so big that its flow is in the middle of its efficency range when the engine is at its redline. I much prefer having a car thats matched so that in the middle of its rev range, the turbo's are pumping at the middle of their efficency range as well.
And dam! 500rwhp in an evo! Those poor tyres... :D
AWHP EVO, not rwhp haha - and it put its power down extremely well, its an absolute monster on a race track.
I don't mind big turbos, they have their place - I just hate it when people under or oversize their turbo for their setup. For example, that evo running 280degree cams and revving to >8000rpm on 29psi is running not overly short of the choke line of the compressor map at redline but it is a huge turbo on a small motor. On the other hand I reckon a lot of people on SAU using GT-RS are running them beyond their efficiency (both hot and cold side) and I'd hate to imagine what life would be in the exhaust manifold of those things.
Anyway, sorry to thread jack Nytsky - I find it hard to avoid this thread as I am amping to see how your car goes, when do you expect it to hit the dyno? :down:
(edit after seeing Cube's response) Yes, you hurry up too ;) I eagerly await both of your results and impression to help decide the fate of mine haha
Edited by Lithium
I ran a GT3076R .82 on my stock RB25 for 18 months, it was nice once you were moving, 1st gear and most of second was a nightmare because the turbo just hit so hard it would just wheel spin all over the place, even in 3rd it was a hand full coming into boost because of how hard it hit, more like a light switch, I then switched to a GT35R .82 and it was far better, much easier and more fun to drive, I can change gears at 5000rpm in 2nd into 3rd and stay at 1bar (my low boost), My customers RB25 is running a T04z and I personaly find that even easier to drive on the street in lower boost levels than the GT35 purely because its much smoother and more progressive coming into boost and having a 4000rpm band of 1.5bar makes it just as easy to drive as my GT35R (besides that it KILLS me in a straight line) I also find around a track that big turbo is also a lot easier to drive because you can give it a lot more pedal in and coming out of a corner and you can feel it starting to power up vs the smaller turbo's where they just hit and your left going sideways.
Just my 2c on why somtimes larger turbo's can actualy make it easier to drive.
lol you sooks
I run a GT3076 with a 0.63 rear, and it makes 314rwkw, and 720nm of torque.
Drives like a V8. Curve was exactly the same as my mates 300rwkw LS1, except he had a bit more torque under 3,000rpm.
I wish mine was like that, I would get to 3300rpm odd and BANG 1.5bar, tire smoke and drama, probably why I only managed an 11.6 with that turbo, the pull away was a nightmare almost always a 2.1 or 2.2 60ft. I think with the weight of your R33 vs my S14 also would make it a lot more noticible for me, I am now doing 1.8's and 1.9's with the GT35, high 10 here we come.
if its that bad maybe try a good boost controller, i know my avcr is able to be programmed for each gear and in 1000rpm increments, using one of those will get you the full power of the 3076 up top but more controllable down low.
Maybe it was the setup? Were you running an aftermarket exhaust manifold?
I run the GT3076r .82 IW on the RB30DET. That pretty much makes a psi straight off idle then ~5psi at 2000rpm; 9psi at 2500rpm and then 19psi odd at 3100rpm.
Boost is fairly tractable with simply less throttle input; or I just grab the next gear and let the torque lug it out. :ermm:
Yeah it was an aftermarket top mount with 38mm tial, could happily run .8bar, but even with .8 it hit had with the Profec b set to zero everything low boost it would hit hard and would try to come in very fast around a track, then again my "coming in hard" could be different to your coming in hard, I stuck that turbo on an SR20 and it was a joy, came in beautifuly! even ran faster than me at the same boost :-(
Anyway, sorry to thread jack Nytsky - I find it hard to avoid this thread as I am amping to see how your car goes, when do you expect it to hit the dyno? :ermm:
(edit after seeing Cube's response) Yes, you hurry up too :) I eagerly await both of your results and impression to help decide the fate of mine haha
Will be going to the exhaust shop in a week or two,then its off to the tuners so it will be on the road in a month id say.
On a side note my throttle cable is now too short for the plenum and trottle adaptor.No matter how i run it,it wont work.There must be people running the same setup as me who have got around this problem. Any suggestions??
Z32 throttle cable
did you have to roll the gaurds to get the rears to clear?
what size tyres do you run?
Nope,did not roll the guards.The offset in the rear is +42,and 265 wide tyres. The tyre sits about 10mm away from the coilover.
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
