they can be pressed out pretty easily
then either tap some threads or press some fittings in the covers and you can use earls stuff
ive got a set here that have had the stock fittings pressed out and earls 90 degs pressed in
I have not got much to do to the engine now so i might give it a go and pull them out.
could get a nice Red R Racing one made to set it off if you like :(
Whos to say im not getting that sticker made??? :)
I thought as much. Looks like ill have to make do with the stock ones.
Anyway here is a new pic i took with the coil pack in bright silver:
post-32255-1214773843_thumb.jpg Looks like a Tomei "DERIVE" engine lol
Looks awesome in the sunlight.
Im getting a sticker made to replace the 2500 24valve logo.
Looks great mate!
Roughly a month. There was a set back with a top piston ring. If it went all smoothly probably 3 weeks.
The car is getting picked up tomorrow morning to get all of the finishing touches done and will be running hopefully on Friday afternoon :D
awesome build up with great pics, your workshop got that motor together in sweet time! what was the actual time from dropping off to picking up the built motor? a quick look at the post dates says somewhere about one month? nice!
any updates?
yeah we like to have them on a one month turn-around. Although we are quick we are also very thorough. All tolerances are checked and double checked and clearances less than spot-on are not acceptable. I actually sent Dave's crank back to be re-done on one of the journals as it wasn't to my standards.
Got 3 tough RB26 builds on at the moment for other forum members, two from interstate...one a big 2.8 stoker...nice.
Edited by DiRTgarage
some people like to remain anon.
lol or are too lazy to start one!
cant wait to get my one Paul, so excited! I havent sent the bearing yet, sorry havent had time to visit the post office.
Dave, im pretty sure I have a 4inch K&N at home if you cant find a retailer who stocks them.. PM me if you need it
Too late Johno, i picked up a HPI 4inch pod from JustJap this morning.
Car is at the exhaust shop, was talked into fitting a 4inch body Metal Cat,suppose to flow nearly 1000CFM of air!
Going to the tuners tomorrow afternoon, but i wont have the car back until mid next week. Adam is going to spend alot of time on the tune so it is perfect,cold start the lot.
Why get one workshop to build it then another to tune it? Any particular reason?
I refuse to touch Haltech's...Why? not because they are inferior...its because i dont know them....unlike other workshops who don't know what they are doing and learn on the fly with other peoples hard earned cash. Adam is the Haltech expert and im more than comfortable Dave taking it to him. He'll do a top job....can't wait to see some results.
You're not the only one. Quite keen to see how it goes down the 1/4, assuming that will happen?
hey nytsky if paul wants to start a topic of the build on my motor im more then willing to let him..... ya know the big 2.8stroker one..... but yes ur rite im too lazy to start one hahahahaha. just think of it as advertising for ya hey paul lol im keen to see lots and lots of pics of the build neways so bring it on
Edited by skylinekid
im keen to see this 2.8 build so i can compare it to mine! :O
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
