Ooow I have a Synchronic 50mm Wastegate also, Let me know if you find somewhere local to get the brass fittings from I can't find anyone here in brisbane who has them.
What brass fittings are you talking about?
lol the ring that goes between the wastegate and manifold is copper... but the little brass air fittings I cannot find, as to use it with a AVCR etc. you need to link A and B ports together and seal the top hole to act as the top of the WG and then use C or D for the lower depending onf the boost level required
But with the Aud $ the way ti is getting a little brass fitting from Synapse will cost around $40 after conversion and shipping costs for somethign so small.
Ill be using C and D for my base boost level.
Have you tried taking it to Pirtek to see if they have anything that will fit?
from memory mine will only be using port D with some preload adjustment. afaik you just leave the ones you aren't using unblocked?
Hmm, I was told by them to link A&B together to use As the top feed back to the acuator and then c or d as the bottom feed back to the acuator
What sort of base boost level were u getting? I am hoping to run 14psi, 20psi and 28psi with my new build
Its not in yet, looking at 20-22 psi, using the 50mm valve seat, the 60lb spring. From what i got reading the manual that comes with it i should only need to use port D and some preload to achieve this (i wont be running an ebc i only want the one boost setting)
In my RB25 /T04z twin scroll w/ 100mm run offs to 50mm synchronic I run it like so:
Stiffest preload spring
A&B joined to my EVC6
C- boost
This gives me 13psi low boost and it is dead stable till 27psi, youll find that you have to run the offset right down, so you could in essence just use B for your boost controler or A depending on how much "gain" you want to run on the solonoid/stepper.
Fantastic WG, I use teflon lines with quick couplings so switching it around as I want is cake... but where it is now is perfect, 2nd gear is easy to hold straight at 13psi and as im into 3rd the evc gives me 19psi and 4th and 5th are 25 to 27psi.
Hmm I can't wait to hit high boost of 28psi :P
I hope you get yours back on the road by the end of the year Dave. After reading about your belt I didnt wait to change the tension on mine got straight too it, I'm using the same belt
C- boost
That sounds like an awesome setup. Stepping the boost up through the gears would give you great traction.
Yeah its set up to boost higher as speed increases, the boost controler was one of the best traction devices I ever purchased :-) , got the combo in an S14 so the power to weight is pretty high for a street car... The T04z on the other hand is pure love! in 2nd shes all in at 4200rpm and 3rd shes at 28psi by 4000rpm giving it a very strong 4000rpm long powerband. Far more pleasant/easier drive than when it was fitted with the GT35 .82,,, now just to pull off an AWD conversion.
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
