No, its the Garrett version, I cant see paying near double the price for 100-200rpm worth while, rather spend that money in more usefull places.
I think the biggest thing with a T04z is if you want it to run nice on the street is to use a well design twin scroll manifold and use a smaller A/R turbine, I find it far easier to drive because it rolls into boost much smoother than the GT35, top end responce on the track now is also night and day, I chopped off 2 seconds around our 1.20ish track swapping to the T04z, on the street you can feel it powering up at 3000rpm by 3500rpm its at 7psi and by 4000rpm its on fire, suits my driving style perfectly.
hi all,
Car is back on stands, engine and driveline are out.
Have to go to Bunnings to get 1 engine stand bolt!! (seem to have lost one)
Then it will be getting stripped down.
Surprising how easy it is to pull an engine out once you have done it a few times.
Car was up, engine and box was out in an hour lol Probably could have been quicker but i spent 10mins trying to get the circlip off the shifter with a set of long nose pliers :)
hi all,
Good fun those circlips got to love em lol
OK just an update.
Rather than fix the damaged head (which looks like it would cost alot to weld up and grind) i purchased a whole RB25DET long engine and will be using the head off that.
But everything in that head will be replaced ie: Valves,Guides,Seat,Valve seals the lot. So it will be a brand spanking new head when its all finished :)
I also bought new pistons (Mahle) and i cant believe the quality of these things! ( :( Steve-o )
Ultra light, Teflon skirts, carbon rings very nice indeed.
And i have sold the Poncams and replaced them with HKS items in256 8.8mm ex264 9.0mm Just so i can squeeze a little more out of my setup.
Things have been rather busy so the bottom end is still not stripped down. Hopefully next weekend we will get cracking, we now have 2 engines to strip :)
Where is the best place to get Mahle pistons for a Rb26/30? My engine builder wants to use CP but I'm keen to check Mahle out.
Matt
you'll be extremely lucky if you can find a set in the country. best bet would be to source them from the states
Matt
i bought my set from http://www.importperformanceparts.net/
tho they are bit more expensive with the current exchange. tho fairly cheap still.
they dont list a price, but trust me when i say its the cheapest i could find!
Edited by Angus Smart
Matt
Hioctane check them out where i purchased mine. Also mahles arent & easy piston to fit they require a lot more mods to fit as they hit oil squirters have to be spaced to fit properly. they arent like your cps or arias that go straight in & theres something else as well cant remember but overall once there in there nice. They are prob one of the best piston around.
You sure thats the way with rb26?? i recall something about sr20 needing to be notched. but the rb26 were ok.?
Yeah im sure about the 26s have somethings that have to be adjusted to fit the mahles. Ill ask andrew who built my engine & let ya know. something about skirts hitting somewhere & something else. But like i said ill ask him & let you guys know
That's ok, my Rb30 doesn't have oil squirters. Are the rings ok if you can get them in without breaking them?
Note to self at work
www.hioctane.com is a porn site
www.hioctaneracing.com.au is the one I want
lol
Edited by BoostdR
I would think very carefully about that. RB26s also have oil squirters... if their RNN14 pistons foul the squirters there's a good chance they don't clear the 26 ones either. i would check it very carefully. :P
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
