If you don't mind me asking, how loud was the belt before the failure?
Both Adam at JEM and Dave listened to the belt and it sounded good...it was the bolt that failed. Recently another bolt has failed in an engine in Melbourne. Ive re-engineered the set-up now as 15 year old bolts may have a fair bit of fatigue and may have been the cause....not the belt tension.
is it worth replacing the idler bearing bolt then in future builds?
ive designed something a little bit better than that...im just waiting to see the final product from suppliers and ill post it up. If it doesnt work im going to use a high tensile cap bolt with a slightly improved thread length.
but yes as a minimum id recommend fitting new genuine bolts with each bearing and belt kit fitted.
good luck with it. hope you get some good results after some rotten luck. looking forward to seeing what you get.
It can only get better after having an engine let go.
But yes cant wait to get behind the wheel of it. Ill have to learn how to drive it again, im getting used to the power of a 1.5L FWD ;)
Does anyone have a part number for the bolt? Also Dirtgarage let me know if your design works as I am in the process of building my RB26DETT from an R32 and want this done right, read about some bolts failing in the US and it has me quaking in the boots after buying some new Tomei parts.
  • 4 weeks later...
Wow its been a long time.
Engine will be picked up on Sat afternoon. Still waiting on some shiny bits to turn up before we can put the engine in though.
Purchased all oils,plugs and filters today.
In the mean time the car has had the new suspension installed. Will be swapping the Bride seat out for something a little more hugging.
And also got around to putting my HID kit in.
this one didn't take long at all 8 weeks including 2 weeks off at xmas ( i normally quote 6 weeks)..the whole drawn out process has been though. I dont know who will be happier at Powercruise...me ripping skids in mine...or you in yours!
Edited by DiRTgarage
I read this whole post last night, started at 2am and fell asleep with the laptop on my stomach. Dave I hope you get to enjoy this weapon for a long time to come once she is back in good health. It sounds like you have the right people involved!
1 + 1 = window
classic.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
