Ok the new injectors,valve springs and engine mounts arrived.But it looks like i have wrong mounts :banana:
The ARP exhaust manifold bolts also arrived,and finally that completes all the ordering for the build.
Now its all the small things i have to the running around for.
Things like a universal mount for the Greddy oil catch can.
Getting the rocker covers painted.
Working out the lengths for all the braided lines.
I have to clean the engine bay :/ im trying to think of a way to clean it without removing all the lines and hoses.As its not that dirty im thinking of spraying the front clips and fire wall with some sort of cleaning solution,letting it sit for 2mins and hosing it all off.Then hopping in with a rag to get all the stubborn stuff.
What would you recommend? Quick detailer? Maybe something a bit harsher?
gurny? :banana:
if you've got a compressor just hook up some hot water mixed with concentrated degreaser (which you can get from bunnings) into one of those spray can things you can get as an attachment. would probably be better for getting the grease off cause you can mix degreaser into it. thats what i do.
Once it's getting reassembled and you've worked out exact dollar signs it'll come together and you'll start to feel great :blink:
I'd love to do what you're doing, looks exciting and engrossing. You'll be having some serious fun when it's complete :)
Love the pics. Keep em coming.
Dont work out the exact dollars; it ruins the enjoyment!
OK all, today everything was delivered to Paul. Top bloke :P and was even lucky enough go for a blast in the GTR. Which was insane! Its not everyday you get to ride in a genuine 9 sec GTR :D
BP98 with 6 deg total timing removed @ 15 psi and 1/2 throttle is not really the way to show off the car...
but...
im sure you got the idea how nuts it is to drive. :D
Edited by DiRTgarage
Just another small update.
When i bought the 3037 a few months back i noticed it had a 4 inch diameter inlet,and thought i would have to either put a 4inch step down to 3inch silicone joiner on the turbo or try and hide the joiner in a custom CAI with the AFM,as the AFM diameter is 3inch.Neither of them tickled my fancy so...
It just so happends, i managed to get my hands on a Haltech E11v2.
So my beloved Power FC and Z32 AFM are for sale.Look in the for sale section for the thread :laugh:
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
