killler setup i hope it works out, im sure it will with the guys your working with. I would swap out the 38mm gate though for something a bit bigger it is marginal at best with a 3037.
You wanna see it!?
Ive been walk drifting around my house and making screamer pipe noises! Haha
Paul broke 2 bones in his foot,then got sick and the machinest wife had a baby.Boy did pick a good month to get a motor built.
blocks been acid tanked, crack tested, decked, bored and honed. Crank collar was machined on today and journals polished. Head has been stripped late this afternoon.
im planning on doing the same thing in the near future, can you give me an estimate on what the block work will cost me?
so far all i have on the list is:
forged pistons
upgraded rods, unsure of which ones
N1 oil and water pump.
thats purely internals, dont know what im doing with the head yet, just trying to figure out what i want and what its going to cost.
Head was done on friday. Full head service,new Tomei cams and Tomei valves springs put in.
Everythings nice and pretty so ive been told.
JUN collar fitted to crank.Crank,rods and pistons were sent away to be balanced.Should be back by the end of the week for assembly.
Home stretch!! :(
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
