Ha. I wish. Give me time to kill this one :cool:
I want to get the car engineered so im getting a few little things sorted out plus a body kit fitted and painted.
Im also seeing some of my mates making crazy power figures, so a slightly bigger turbo might be on the cards.
I forget, do you drag race? I'd love to see what yours would do down the strip, I'd have thought that it'd be in the vicinity of 10s on decent tyres? Surely there must be some temptation to bust out a real fast time like that using far less turbo than most do :thumbsup:
Ha. I wish. Give me time to kill this one :thumbsup:
a t04z? dont do it, keep the 35 on it with a .82 and spend money on the head. that should see close to 600hp at the tyres with everything working properly
Dave ive got a nice twin scroll turbo here on the shelf. Its a little larger than what you have now that you can borrow for a 'suck it and see' test session if you like.
Come pick it up if interested.
If i do decide to upgrade the turbo it will be a GT35R .82 w/ported shroud like the 3076 i have now. Love the sound of it spooling :D
Also might see if i can get the collector cut off the manifold and have a split pulse one welded on.
It is a difficult choice, as the response VS power of the setup now is insane.
If i do decide to upgrade the turbo it will be a GT35R .82 w/ported shroud like the 3076 i have now. Love the sound of it spooling :)
response is king for circuit and street
i personally think you would be insane to do this... a friend had a rb25 neo with cams, greddy plenum etc and was a cop with a 3582r, convinced him to downgrade to a 3076r and now its awesome!!!
Edited by Cerbera
i personally think you would be insane to do this... a friend had a rb25 neo with cams, greddy plenum etc and was a cop with a 3582r, convinced him to downgrade to a 3077r and now its awesome!!!
REALLY?
my Mechanic got a 33 tuned with a 3582 with a .84 rear and got the lag down from 4200rpm to close to 3200-3500rpm.
To me that is bloody good, keeping in mind the size of the 3582. That is almost the same amount of lag as my .63 3582, bloody amazing.
Edited by r33cruiser
Do what you said above, split pulse the manifold and go a split pulse GT35 - probably will be never quite as good as the GT30R but closest thing to having your cake and eating it too :thumbsup:
i just put a gt37r on a supra, you know you want to. do it. :):thumbsup::laugh:
Is that the one softy was telling me about?
How does it go up macpass?
id love to hear what you think as ive got the gt3566-82r here waiting for my supra
New workshop looks the goods!
If i do decide to upgrade the turbo it will be a GT35R .82 w/ported shroud like the 3076 i have now. Love the sound of it spooling :P
Mate call up GCG and talk to them about a 66mm front fan ;)
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
