If i do decide to upgrade the turbo it will be a GT35R .82 w/ported shroud like the 3076 i have now. Love the sound of it spooling :(
Also might see if i can get the collector cut off the manifold and have a split pulse one welded on.
It is a difficult choice, as the response VS power of the setup now is insane.
It may not be as simple as cutting off the collector and welding on a split pulse collector as the runners would need to grouped in such a way that each exhaust pulse fires into the correct side of the split pulse collector i.e. based on the firing order of the engine, each alternate exhaust pulse must fire into the opposite collector - otherwise high exhaust back pressure in the collector will be the result. Therefore, you would need to examine your firing order and exhaust manifold runner layout and firstly confirm this.
Edited by juggernaut1
if it's still the original stainless manifold it isn't going to be an easy job to get it split properly. Its one with around 80mm of steel sheet between the merged runners and the flange so probably more dollars in custom work than it's worth. You'd basically have to remake half the manifold.
Even with a 6 boost or etm you'd have to chop off the merge collector and redo a fair chunk of manifold to get a decent result.
Is that the one softy was telling me about?
How does it go up macpass?
id love to hear what you think as ive got the gt3566-82r here waiting for my supra
New workshop looks the goods!
Mate call up GCG and talk to them about a 66mm front fan :thumbsup:
thats the one, drove it for the first time today on 5 psi, went well. might wind some more boost in tomorrow.
i just put a gt37r on a supra, you know you want to. do it. :/;):P
How did it go? we have a built jobbie with gt40 on it, customer underestimated the setup and injectors ran out @ 425rwkw i reckon low 500's @ reasonable boost. I only ask as i have a 2.5l (from gizzmo elecronics) soarer here also with a gt40 and i reckon the 37 would have been better.
Got a graph by any chance?
  • 2 months later...
Been a while so here is an update.
The GT3076 has been pulled off and will be replaced with a GT3582.
The new turbo has the new .70 surge slotted comp cover and .82 housing in single entry.
Had a nice oil catch/breather can custom made, with Speedflow fittings and braided lines snaking their way to new RB26 cam covers with Hi Octane Racing cam cover baffles, should keep the high RPM oil splashings at bay :)
The 26 covers were powder coated by "Craved" from CRAVED COATINGS, turned out very nice indeed!
Also have a Trust clear timing belt cover that will have to be "modified" so the VCT has room.
On our recent trip to Japan i picked up a Tomei Trax 2 way diff which ill be sending to Award Diff and Gearbox for them to work on.
Another tune is planned for the end of this month, should make around 420kw+ at the rears.
Gearing up for another big Powercruise in Feb. Cant wait to hand it to the big boys :)
That is excellent mate, feel free to share some photos when you can. I think I have to plan a Japan trip for some parts reconnaissance, so jealous after looking at those photos.
Good luck.
Post up pic's when you modify the cam gear cover :) I have RB26 covers on mine at the moment but left the RB25 cam gear cover on, it aint a perfect fit, but it aint that bad. Was thinking of getting a RB26 cam gear cover and modifying it.
You just going to cut the hole so the VCT sticks out a bit?
Edited by PM-R33
good sh1t Dave...wick her up mate. My car is coming back with me when i return at the end of the month...Powercruise is in Feb. eh?
Get in on it Paul. Nothing better than flying past blokes with engines sticking out of the bonnet.
Yeh have to get a small hole cut in the front of the cover, being clear plastic it shouldnt stand out hopefully.
yes and yes.
looks like you'll kill me on the straights though.
are there corners?...im out :)
might have to contact Peter at Fuel Control and get him to organise a 205ltr drum of CSR's finest to be delivered to us at the track.
Edited by DiRTgarage
Nathan/Dave, call me about supercruise :)
also Dave why the rb26 covers? Usually gtst owners just put the rear gtr badge on and leave it at that :) .....I'm expecting you to say something about oil control here
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
