Looks good!
I'd like to see how you plumbed up to the factory pump too, I'm collecting all the bits to put swirl pot and couple more 044's in at the moment, not sure whether to go for braid or the push-on hose that earls do!
http://cgi.ebay.com.au/EARLS-10-SUPERSTOCK...=item27ae77bd34
Looks good!
dont use the push on hose for unleaded fuel.
both gates and speed flow say their hose is unsuitable so I would assume Earl's would be the same.
I think they all say that, same with the stainless braided, only one suitable is the teflon and unless I win the lottery I cant see that happening!
what should I use?
We can supply you earls teflon lines at a very reasonable price, email me for a quote.
180or200 - For ideas you might want to see how we connected up the factory lines and used the standard pump as a lift pump.
Link: http://www.skylinesaustralia.com/forums/Ps...g-t242907.html#
Dave - Curious as to why you kept the standard TB? I would have thought you would go have gone the Q45 for that power level. Also keen to see how the brakes hold up on a track day with the wastegate so close to the ABS unit.
your thread doesnt show the actual connecting to the plastic part of the tank though
Sweet engine bay Nytsky!
As quoted previously, turbo dump pipe should be as big as possible. Thats why you see see turbo drag cars just have enough piping to direct it away from where it might melt something and that is it. Bigger = better after the turbo. Obviously on a street car there are physical limitations that you have to work with.
The GT3076 has been pulled off and will be replaced with a GT3582.
The new turbo has the new .70 surge slotted comp cover and .82 housing in single entry.
T3 or T4??
I'm debating whether to go for the Twin Scroll GT3582R T3 0.78 or T3 0.82 or T4 1.06, arghhh the choices!!
Have been in an EVO running a twin scroll 1.06a/r GT3582R, the spool is seriously seriously impressive.... I have a .82a/r GT3076R and I'd honestly not expect to feel too much compromise going to a T4 GT35R.
  • 2 months later...
how is the car going with the new 3582, im just finishing up my 26/30 build with this turbo and would be interested to know if this turbo will give me 550hp at the wheels
oh and how much to get my comp cover slotted cos i would really like to have that 51r spool noise
It has been garaged since Powercruise.
Adding a few bits and pieces.
Unfortunately the noise from the 3582 is nothing like the 3076 i had, even with the surge slot cover. Makes me want a T51R KAI now :blink:
Thats interesting dave, i can play waltzing matilda on my surge ported 35/82. Wonder if the 30 bottom end makes a difference.
Hi Noel,
It does produce a noise, id say half as loud as the 3076.
Was nice to meet you at Superlap on the weekend :)
DOOOOHHHH! I never connected the dots. GRab me by the ear next time mate. would love to have a good yarn with ya. :blink:
    • It's aftermarket. It also reeks of Honda Civic tryhard from 2003. But if you want one....then you want one.
    • Well some mostly good news and some slight bad news.  Good news is cylinder 6 did in fact only require a honing and I'm good to run my 86.5mm pistons again. I should also get the block back by end of week. Bad news, had a few surprises pop up. First, main and rod bearings were trashed. No sign of any heat damage. I knew right away what caused this... I had not packed my oil pump originally and spent a lot more time than I would have liked cranking the motor to get oil pressure. It sounded fine once started so I chucked it up to luck and forgot about it. Luckily rod and crank are fine and just need new bearings. Engine builder agreed that this was the cause.    Another surprise that carbon covered up very well that I didn't catch, something got sucked up and went through cylinder 1, 2 and 3. Luckily this was no cause for concern, just needed a bit of cleaning up. Valves look fine but he will vacuum test the head this week to confirm. I'm presuming this was something left over from welding my intercooler piping, but we'll never know. I'm going to thoroughly reclean everything.    So all in all, happy the motor is fine, and I'll get it back much sooner than expected. I'll also be taking the time to convert my WMI system over to direct port. I'll snap some pictures of that when the parts come in.
    • I understand, thanks. Yeah I wouldn't want the car to tip over, I'll try and use the sills, I don't want to risk smashing the chassis rails. I ordered some rubber pucks that have a hopefully big enough slotting. If the front right gives me trouble I can always just make a wood block. I'll measure and inspect the sills closer once I actually take the car up. I hope so, but the rubber blocks I had in hand so far were pretty damn firm, if they are that hard they won't give much way. I'll let you know what happens. Angle grinding rubber isn't one of my favorite tasks. I'll probably start a build thread soon, for my own documentation and "log" as well as sharing what's going on with the car.
    • Kinda something I have been thinking about.  To be honest, we bought it already driving like that.  So there's no telling how long it actually has been driving like this.  Hopefully damage is too bad when we drop the pan.   I am having a hard time finding a site that sells the solenoid for the 5 speed auto, do you have any suggestions?
    • That'll be most likely down the road...  LOL
