Hos high is the turbo sitting? Or is it just the angle of the photo. Would think you could have bonnet clearance problems, or at least need to protech yourbonnet paint from temps? .. Great looking engine
That is how it sits, it will clear the bonnet and i have reflective high temp adhesive above the turbo/gate.
What turbo, I thought you were going to order a GTX35?
Its a GT35R, the new head and turbo (GTX35R) will go on just before powercruise.
Is that a standard water pump??
Standard RB30 pump.
Engine bay looks nice and clean!
Why is the turbo so high?
lol. I remember a bloke with a super high single and bonnet closure problems.... who was it again? :ph34r:
and I do enjoy the VL super high mount. be a bastard cleaning all the dead bugs out of the mesh though... :down:
Seeing as i work nights i dont expect many phone calls or texts at the wee hours of the morning, so i was a little surprised at 2am when i get sent these:
Paul was up all night putting some finishing touches on the engine before the install this week. The hours spent on this project to date can add up to weeks. All the fine detail work takes alot of time!
I am very grateful for all the effort he has put in on this thing and i believe it is as much his as it is mine.
VCT? its still a 25 until next year?
I thought the stock VCT was just a solenoid on the left which interacts with the head, didn't think it did anything with the cam gear. I also thought it was on the exhaust cam only, but could be completely wrong.
Reason I ask is there are full adjustable (change based on rpm) cam gears that look similar to what is on his intake cam, they are around $3000 though from what I've seen, fairly complex piece of hardware.
Edited by Rolls
nah, take a look at all RB25DET cam gear covers, all have the bulge for that camgear
    • That seems like a very special issue!  Does it affect both sides? Either way, I would disconnect the driver's side switch and see if it still happens, noting that might require removal of the whole door card which is a bit of a pain (it does on V37 and HY51)
    • MBS206:- The windows start to slowly open themselves. GTSBoy:- Battery is new since Dec.
    • I currently have a 2008 370GT Coupe, with the big brakes (Akebeno if I'm correct), and Its coming time to get new pads. Previously, I had a 2003 350GT Coupe with the stock sized brakes, not Brembos. I had custom wheels on it that were pretty open to the brakes, and when I first put the wheels on it, the rims where completely coated with brake dust. A few years after adding the new rims, I needed to change to pads on that car. I didn't do any research, but I told the mechanic of the problem with the brake dust. I also told him I didn't track the car or even drive around the streets harshley. But the dust was an issue. The mechanics changed the pads to a different compound, and the dust was GONE! The other change I noted was that when coming to a complete stop, instead of having to press harder on the pedal as I approached 0kph, I had to actually lift off a little to not come to a hard jerky stop.( My unfounded explanation is they became stickier as they heated by stopping ) Since I got my 370gt with big brakes, I noticed that that as I came closer to stopping, I had to press harder and harder to reach a full stop. I am not talking about hard, just harder. I brought the car in from another state, so when I had a blue slip done, I asked the mechanic what he thought of the brakes, and he thought they were brilliant. The only negative of these pads on the 350GT, was that they squealed when cold. So driving out of a shopping center carpark, it was a little embarrassing, as the brakes squealed, and I am sure people thought that I needed new brakes, when they were actually fresh. I have no idea of what type of compound they were on the 350gt, but whatever it was, I want to get the exact same on my 370GT. They weren't ridiculously expensive, and were replaced at the local JAX (which is no longer open), so I am certain they would be a pretty common big brand, off the shelf type/brand. My current mechanic suggested I need top get the rear pads changed soonish, but he suggested standard Brembo pads. Which I expect to behave the same as the current ones and not like the ones on the 350GT.  I don't think dust will be an issue on the 370GT. With the behaviour I describe above on the 360GT, does anyone have a suggestion of pad material that will act like the change I had done on the 350GT?
    • The consult isn't even OBD1. It's a Nissan Consult. Proprietary.   Re read everything I've said. I specifically say, put down the laptop/tablet. Understand, and review the issue first. Logging voltages is the same as logging the converted value. Things like O2 that you say to log, is unusable for this, whether it be the voltage, or the value the ECU thinks.   The fact you don't know how to diagnose without looking at the computer, is exactly what I've said multiple times is the issue for why techs these days can't diagnose the fun issues with cars.
    • Breather for it. If it's anything like the GTRs it should run up to the top of a bellhousing bolt.
