Red R?
yeah Paul at Red R is responsible for the design and fabrication of this pornography. Im currently putting away a few beans each week to get one for the VL soon.
Edited by Supa Steve
  • 4 weeks later...
  • 3 weeks later...
past the cat it makes no difference, especially at 4 inches!
My exhaust goes from twin 3" into a single 3.5 into a 5" muffler. I ran twi3 3" side pipes at the track and my boost rose to 2.3bar from 1.6 with no other changes. At 450rwkw+ twin 3" is the only way to go. A sinlge 4" flows 12.5% less than a twin 3" but without the associated cost...
For interest sake a 4" has 20% more area/flow than a 3.5"....
  • 5 weeks later...
Been a few weeks, so time for another update.
Trailered the car from Pauls to Wholesale Suspension in Penrith.
Had to have the front swaybar re-bent to give a good clearance from the sump. Custom mounts and all new bushes were also installed.
I had some adjustable rear camber arms installed to get the camber back to 0 for better traction.
The car was also raised 10mm.
After that the car was trailered to Shauns Custom Alloy. The new intercooler has 3inch ends and im now using a Q45 throttle body so all new cooler pipes had to be made as well as a new intake, which now has the pod mounted through the guard.
A new catch can was also fabricated which now has the breather hidden :ninja:
One small over sight was the stock clutch fan fouling the pulley for the external oil pump. So an alloy radiator and dual 12inch thermo fans will now be used for cooling.
The car was then trailered to JEM where it is now getting the final touches and awaiting dyno time.
Just Engine Management are now agents for Zeitronix. Zeitronix are a US company and are famous for their award winning Wideband/Lamba kits and monitoring gear.
JEM will be fitting a Zeitronix Zt-3 + ZR-1 AFR and Lambda Gauge Display Bundle.
In this kit the Zt-3 Wideband is bundled with the ZR-1 Gauge. The ZR-1 Gauge displays Air/Fuel ratio or Lambda values and has a peak and hold feature. High contrast LEDs are visible even in a direct sunlight.
Includes the Zt-3 Wideband Air/Fuel Ratio Meter, Sensor Harness, Signal Harness, PC Serial Cable and Installation Instructions. Data splitter included for simultaneous display and datalogging use.
Available with or without the wideband oxygen sensor. Made in the USA.
More to come soon.
Exhaust is finished, work of art! I bought 2 cats, one 5inch 400cpi Euro 4 and one 5inch 100cpi.
Still the same clutch but bought an alloy flywheel from the states.
Should have the car home very soon, just some minor things to tidy up.
Pic of the mid section.
What brand mufflers are they? Custom? They look to be the buisness either way!
Cheers
Justin
ive always been a fan of the lobster back bends as i appreciate the workmanship involved - nothing beats it!
is there a performance gain from this though as 1 would think that a mendrel bend would flow better as it is a smooth curved edge & there is no weld edge on the inside of the pipe - i guess the difference is within a bees d1ck anyway lol
its done cause its cheap and if you hvae a drop saw if actually quite quick to do. Your correct it does not flow as well as a mandrel bend.... but costs a 1/4 to make.
How come ur running a pod under the gaurd?
Arent u keeping it legal?
It will have an airbox so the pod wont be seen. I can always shorten it if it becomes a problem.
There was nothing cheap about this exhaust unfortunately as it was the first made. The subsequent ones will alot cheaper as the design is already done.
Sorry dave didnt mean to offend, the question was asked why lobster over mandrel bend and i just pointed out why its done, i can imagine the mufflers alone were quite exy.
    • I currently have a 2008 370GT Coupe, with the big brakes (Akebeno if I'm correct), and Its coming time to get new pads. Previously, I had a 2003 350GT Coupe with the stock sized brakes, not Brembos. I had custom wheels on it that were pretty open to the brakes, and when I first put the wheels on it, the rims where completely coated with brake dust. A few years after adding the new rims, I needed to change to pads on that car. I didn't do any research, but I told the mechanic of the problem with the brake dust. I also told him I didn't track the car or even drive around the streets harshley. But the dust was an issue. The mechanics changed the pads to a different compound, and the dust was GONE! The other change I noted was that when coming to a complete stop, instead of having to press harder on the pedal as I approached 0kph, I had to actually lift off a little to not come to a hard jerky stop.( My unfounded explanation is they became stickier as they heated by stopping ) Since I got my 370gt with big brakes, I noticed that that as I came closer to stopping, I had to press harder and harder to reach a full stop. I am not talking about hard, just harder. I brought the car in from another state, so when I had a blue slip done, I asked the mechanic what he thought of the brakes, and he thought they were brilliant. The only negative of these pads on the 350GT, was that they squealed when cold. So driving out of a shopping center carpark, it was a little embarrassing, as the brakes squealed, and I am sure people thought that I needed new brakes, when they were actually fresh. I have no idea of what type of compound they were on the 350gt, but whatever it was, I want to get the exact same on my 370GT. They weren't ridiculously expensive, and were replaced at the local JAX (which is no longer open), so I am certain they would be a pretty common big brand, off the shelf type/brand. My current mechanic suggested I need top get the rear pads changed soonish, but he suggested standard Brembo pads. Which I expect to behave the same as the current ones and not like the ones on the 350GT.  I don't think dust will be an issue on the 370GT. With the behaviour I describe above on the 360GT, does anyone have a suggestion of pad material that will act like the change I had done on the 350GT?
    • The consult isn't even OBD1. It's a Nissan Consult. Proprietary.   Re read everything I've said. I specifically say, put down the laptop/tablet. Understand, and review the issue first. Logging voltages is the same as logging the converted value. Things like O2 that you say to log, is unusable for this, whether it be the voltage, or the value the ECU thinks.   The fact you don't know how to diagnose without looking at the computer, is exactly what I've said multiple times is the issue for why techs these days can't diagnose the fun issues with cars.
    • Breather for it. If it's anything like the GTRs it should run up to the top of a bellhousing bolt.
    • What basics? With these OBD1 ECUs it's not like the ECU will give you any real clues, it's not really doing any sanity checking of sensors/sensor data. My experience is actually a lot of sensors tend to be the source of the issue first and foremost, and checking everything gives you a direction to investigate. MAF/O2/STFT/LTFT should all kind of make sense. You can try little tricks of the trade like tapping the MAFs to see if it triggers a stumble, things like that. But once you've done a compression test knowing whether you have an air leak or fuel delivery problem is kind of hard to narrow down without sensor data. And you don't really know if all your sensors are making sense unless you can interrogate the ECU directly about what it's seeing for sensor data.
    • Absolutely this. Yes, except not vacuum hose. Something oil/fuel safe is a better idea.
