I had the same problem with my car, exhaust tone was nice but after driving it for 20min u get over it pretty quickly (its a sign of old age, I like to call it maturity lol)
Besides that, when the exhaust db drops, u get to hear more engine noise which is a major plus.
Wont be making the drag day, still need to make changes for it to be road worthy. As the car has been pulled apart and off the road for so long, Adam suggested that the car as a whole needs a few K's put on it just to see if there is anything that needs attention.
So far 200rwkw@10psi 5000rpm. Makes more power and torque everywhere. Feels strong.
Ordered my new plates too :)
RB25/30
Ported head
HKS 256/264 cams
Tomei springs
Nitto headgasket
Nitto/JE pistons
Nitto I beam rods
Block mods
etc etc etc
GT35R.82
6boost manifold
4inch dump
4inch exhaust
I hope the rear housing will be big enough.
RB25/30
Ported head
HKS 256/264 cams
Tomei springs
Nitto headgasket
Nitto/JE pistons
Nitto I beam rods
Block mods
etc etc etc
GT35R.82
6boost manifold
4inch dump
4inch exhaust
Cheers, and I am sure it will be fine... for some reason I thought you were going GTX
Ffs dont waste your time and money with the .82 housing Dave. It will only end in tears.
At the very least use a 1.06 housing and even then dont tune it without egt sensors.
You setup is almost a mirror of mine and the 33 racer car. I wont tell you how any 35r's came to grief between the 2 engines before we woke up. Using the .82 is like f**king for virginity, You wont get the desired result.
What Noel said mate! :)
But if you do manage over 400 with the .82 ill be impressed, especially if the backpressure isnt stupid and you can keep egts below 800c and stop the turbo from shitting itself the first time you go do a track day.
he did manage to pull over 400 on the RB25. topped out at 429kw from memory?
    • Thank you 🙏 I'm patient, which is good, considering the limited budget (for now) more so trying to understand where to begin the journey and you and the others have been good with that, appreciate everyone for their input 🫡
    • $5-10k isn't much for reliability if your looking at more power for a RB Me, with that much money currently on hand,  I would only look at things to suit future mods, as stated, a fuel pump and ecu would be my first point of call, as well as getting the injectors cleaned and tested, maybe even replace all the coolant hoses After a little time with the tuner, they should be able to tell you how your car is running in relation to things like your ignition, cooling, and other stuff that will be picked up when it has had a few runs up on the dyno and some logs to look at Basically, get everything sorted for reliability before you start leaning on a 30 year old engine Good luck with the one and only true Godzilla, enjoy Note: for your birthday presents, ask your family and friends for lottery tickets, a 32 GTR can cost "all of the money" to make reliable power
    • Strictly street. Just wanting a bit more power 🫡 Have baby seat in the back too 🤣
    • Yeah ok, it'll be expensive. But it is what it is.  How do you plan to use the car? Any track work?
    • I do have their “Nissanie Motorsports Co.” vin plates, but I am curious if anyone would have more info on them. Like how many cars they’ve imported and whatnot
