im about to replace my water pump (have to do the timing belt so may as well do the water pump to be safe) is there much benefit in using an N1 pump over using a standard?
I didnt see any. Then again i never had any overheating issues.
i dont have any real issues but i have been told that to replace the water pump its the same amount of work as it is to do the timing belt so i figure i may as well do it while im in there.
Yeh i would replace it too.
The Poncams do not need any adjustment,thats why i did not get adjustable cam gears.
Dont have much experience with RB25 tuning but i know the Tomei Poncams in my old 26 liked a little adjustment. Especially on the exhaust side :P
Edited by DiRTgarage
Dont have much experience with RB25 tuning but i know the Tomei Poncams in my old 26 liked a little adjustment. Especially on the exhaust side :)
I will ask my tuner to spend some time on making some adjustments to it.
I think the affect will be minimal, but hey more power is more power :)
I dont suppose anyone has a BRIDE seat rail they want to get rid of??? :P
I have HKS cams in my RB25 and the exhaust liked a little touch up. I also retained VCT, It was worth retaining I think for midrange but you do get a tiny flat spot as the solenoid opens that we could not really get rid off.
How long till it is ready to rumble?
Pick the motor up this week, the week after ill be putting all the gear on the motor. The week after that ill be getting it towed to my exhaust shop for all of the piping. The week after that ill be getting it towed to the tuners for the start up and the run in tune.
So will be a few weeks yet till we turn the wick up.
My heat wrap arrived this morning. Its called ThermoTech, has anyone heard of this brand? It says it can withstand constant temps of 2000F.
I went with the black as the white gets dirty to easy. 1inch wide by 15m long. Should do my manifold and dump pipe hopefully.
I hear stainless expands more than mild steel when heated. Would it be a good idea not to wrap it as tight as you would normally?
I was planning on trailing the wrap through water as i wrap the manifold so the wrap keeps its shape a bit better.
The black wears/burns/falls off. It just ends up looking dirty anyway. Looks great initially though.
It'll also harden up with heat so just wrap it tight so random bits aren't flaking off with vibration or when you brush against it when doing maintenence.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
