Make:Toyota
Model:Soarer
Milage:120,000
Transmission:auto
Colour:Metallica Green
Complied?Yes
RWC supplied?
Currently registered? Yes
Price:15,000
Contact:0422070093
Comments / Modifications: Plenty read below
Images:
For Sale of Swap is my single hks turbo soarer. i have had this for 4 years and brought it standard. I have spent so so so much money on this car it is not funny.
I want a new project car and im thinking something along the lines of r33 r23 or r34 or supra , aristo, prelude or civic
i dont mind if they are turbo or non-turbo
Just got a new engine put in and had its 100k service completed as well.
Mods are
Single HKS 30/37 Turbo
Single Turbo Manifold
38mm Tial Wastegate (Brandnew)
Full Exhaust with dual 4' tips
440cc injectors
SAFC
Boost gauge
AFR Gauge
Fully Rebuilt auto box with stage 1.5 shift kit and 3000rpm stally
Oil filter relocation kit
Oil Cooler
Trans cooler
Other things are HID kit, Glass High Beams, 4 Brand New tyres, 11months Rego and Clear Indicators
Also has a full Stereo with 7' dvd player including 6x9 and 2 x 12' clarion power system subs with amp
Car runs like a dream and is very powerful, currently this is on a tune of AFR 11 and running only 15 psi i believe with a proper ecu and a tad more boost this puppy would make well over 280-300rwkws
ATM it has 250rwkws
Please feel free to make a reasonable offer or swap offer
I can be contacted on the number above
Ill put this up just incase there is something i forgo to add
http://www.carsales.com.au/used-cars/priva...amp;Make=TOYOTA
Regards
PK
Edited by slaughter
I have seen this car a couple of times throughout its build process, i can gurantee the workmanship & the quality of parts would make for a great street car with loads of power.
Good luck with the sale, it shouldnt last long at that price!
Hello Buggor34
How have you been, thank you for the kind words i know ill never get what i paid todo this or even 50 percent of what i paid to complete this car but i think 15neg is a good price
regards
PK
cmon mate you want a bike with difference you know what they say Hayabusa's are like assholes everyone has one but you could be different and ride around on a 247RWHP turbo hayabusa not many of them around.. swap ya with some cash my way
i have seen this car and it is definitly worth the buy slaughter has put a huge amout of money to get it were it is now, its in great mechanical order nothing needs to be done to the engine or drive train as they are in good order, good luck with the sale slaughter
thanks for the kind words yellowsubmarine, i know that when someone drives it they will love it just as i have!
PRICE DROP 14K NEG!!!!!!!
Edited by slaughter
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
