Hi,
Ive got a standard water pump pully on my rb26, but its a bit out of whack and it wobbles more than id like it to. Actually, its throwing off very small pieces of rubber from the belt, so i want to get rid of it.
My question is: If i replace the pully with a smaller diameter one (ive got an rb20 one), will it spin the water pump too fast and result in cavitation, therby reducing the cooling efficiency of the coolant?
The RB20 pully is 120mm in diameter and th RB26 one is 145mm in diameter.
A new RB26 water pump pully is $143 from nissan and im a tight arse, so im trying to save some coin. But if someone has a good second hand one, let me know!
Shaun.
Cavitation wont effect cooling effiiency, it'll just eat away your engine from the inside out. Wouldnt worry about this unless yout constantly pushing the motor at high rpm.
The only difference b/n them all i think are the impellor size & design (apart from the diff bolt ptrn)
Go RB30ET pump and elongate one of the holes? Ive got a pretty much new RB30et one if u want it
I got one you can have if ya wan't, err somewhere.
Mate, if youve got a standard rb26/30 water pump pulley thats straight, ill grab it for sure. Let me know.
Thanks,
Shaun.
Thanks but the water pump is a brand new N1 item i think. Its definately not stressed in regards to high rpm for lengthy periods. I was just concerned about the different sized pulleys, but i think your right; im probably splitting hairs. Ill just get rid of the wobbly one and put an rb26/30 item on.
Shaun
cavitation does affect cooling efficiency as it means the coolant is not being circulated efficiently. sometimes in the extreme. it also creates bubbles, a big no for mr cooling system. i've seen a test rig with a perspex housing stuck onto the back of chev and ford water pumps driven by a washing machine motor. seeing the flow stall, and even reverse in some circumstances was a bit of a wake up call. serious mods to the impeller fixed it however.
cheers
cheers
Yeah, i thought cavitation was a bad thing; hence my efforts to avoid it. Everyone actually says to go an oversized pulley if anything.
So just to confirm; the rb30 pulley is exactly the same?
Shaun.
Well it does decrease efficiency but not to the extent of what you think, its almost neglible as air is compressable. Your impellor design probably improved the flowrate somewhat
Sorry I wasnt sure about the pulley size on the Rb30et - I was just saying the impellor flows much more than the standard n/a item, probably suffice for the 25det
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I thought you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
