well it might be actually possible, would need subframe off, sump off, crank out, balancer off, timing gear off, timing belt off, oil pump off, gearbox off, clutch off and flywheel off.
but if you did all that you could probably get to all of the bearings.
seriously though, if you need new big end bearings, rebuild the motor. the main bearings are probably in trouble, there is most likely some crap floating around somewhere, might as well do a hone and new rings while you are in there. pull it apart, clean and check it all, put it back together. so much damn work just to get the sump off
You wouldn't have to remove your crank to change B/E brgs. I've changed them on various other motors in the past by removing the B/E caps & spark plugs, pushing each piston up an inch and being real careful not to nick the journals with the thread on the B/E bolts, if you do, crank has to come out (might have to come out anyway for a grind or at least a linish if its got grooves).
You'll have to do a r & r on each cyl that's on the down stroke then turn crank to do others.....pretty messy this way but good oportunity to replace with a decent baffled sump.
As far as mains are concerned, they rarely fail unless there's crap in the galleries but usually evident by pitting or scratches on the B/E shells.
You CANNOT get the sump off with the gear box attached, there are two bolts behind the flywheel. This has been covered before, It is not practical to take the box out, to remove the sump. Just pull the engine, there is no way around it. And yes, I have done it.
Sorry to be a spoil sport
ok thats fine.... just wanted to find out first as i have never worked on a rb26 befor motor has only been rebuilt not long ago.... it got low on oil and now has the knock at around 3 4000 ill get some one to do all the work and check every thing
might be time for the bigger turbos at the same time :domokun:
Fair enough, its good info to know. As I stated above, I have removed sumps on various other motors whilst still in the car but not on an RB, thanks.
yes so have i thats why i asked.....it has cp pistions and a baffled sump ect all ready and light weight rods im not sure what type of bearings were used tho any ideas on how to tell?
Check numbers on the back of the shell, may give a clue, or if your not using them again light scrape on inside will tell you if they're copper leads or alu tins. Always a good idea to use a copper lead or similar in an RB though.
Huh??? Same thing....you gotta remove the B/E cap to remove the B/E brg. What sort of other B/E is there?
Where do you think the big end bearing sits, and what does it protect? The Big End (it's the end of the conrod that connects to the crankshaft).
If you are referring to the big end bearing, then call it that.
Been in the engine reconditioning game for 20 years mate so I appreciate you teaching me something that I learnt when I was still in nappies.
When engine reconditioners say they're changing their B/E's, they're always referring to shells. Otherwise they refer to the rods specifically. They never talk about changing B/E whilst referring to rods.
Sounds like you like to make a play on peoples words and argue pointless issues otherwise you wouldn't have asked such an obvious question.
Sorry, didn't realise you had so much experience in these matters.
Yes, I can be a pedantic old bastard sometimes. It's just that there are quite a few younger members who don't always understand the technicalities.
And the only stupid question is the one you don't ask.
Yeah no probs bud, I know what you mean & I agree, its like banging your head on the wall sometimes. :)
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
