Originally posted by Rezz
Scandinavian Skyline massive represent! Light up those rears right in the middle of a mall!!!
...I dig your English too Klaus...
Haha but im trying the best i can... Is from germany from the beginning thats way it is badly i gues?! =))
How exactly do you meen? Cant you do so and show me?
Regards Klaus:bahaha:
Originally posted by Parag0n
I think it is fine ! ;)
mmm on my next trip i might come to visit you, maybe you could do the next getaway in stockholm vid eh :D
Okey... =) Yes when you are in Sweden pm me or mail me then you should be ready on a cupple of skylines overe here....
regards Klaus
Originally posted by SkylineMannen
Mkey you now the Swedish chicks are soooo hot here =))  :P:D:(
//Cheers Klaus
ohhh shit yeah :)
the company i work for is Sandviken owned.. hmmmmmm... Thinking thinking thinking....
Originally posted by Guilt-Toy
ohhh shit yeah :P
Sandviken i now about yeah.. Makes cnc tools... Then you now there are not both goodloocking they are ..... Aswell =)) And whit a skyline they little honyes goes mad / crazy both in the streets and the bungaloe :whackit:
Cheeers!
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
