  • Replies 238
fark me!
i'm SOOO... trying to get work done sat AM/PM so i can get out Sunday.
If i can't... i'll prolly come to geelong if i can!
AARGGHH!!! why this weekend.. next weekend i'd be laughing.
Oh well... just gotta work my balls off :(
Gordo: The sites listed by Leewah are 'favourite' spots for mobile cameras. There are NO FIXED cameras on the Great Ocean Road. Yet.
The camera locations are usually in the towns where the limit drops from 100km/h to 60km/h. The majority of the 'open' sections of the GOR are 100km/h.
So... we can still play on the main bits of the road - but need to be extra careful in the towns. The lead car needs to be a bit vigilant in spotting typical 'camera cars'.
ok.. that is cool.. i thought he meant fixed cameras. I'll go now.. oh yeah, small point, i need my car back first :) meant to be ready by thursday or friday but not holding my breath - assuming the steering is all fine I'll be coming along.
yes as stated in the first thread these are the meet times for melb.. and are final, rock up at 9:30ish... wil be departing at 10am to meet our lines in geelong.
----extract---->
Date: Sunday 10th August 2003
Meet time: 9:30am (melb)
Meet Place: shell/subway, on the exit ramp of Point Cook Rd (MEL:53, B3. The exit after Newland St)
Departure time: 10:00am (melb)
Destination: Apollo Bay (via GOR)
----extract---->
oh yes.. and ill be there.. hopefully with.. maps/key stages of hte cruise... something to that effect... look for hte line that looks like a top fueler!! hahahah ass is to high in the air with stock suspension at the rear and bilstiens at the front hahah, gota get dem fixed damn it hahahah
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
