Hey guys,
As some people may know/heard the Stagea broke down the other night, had a rattle coming from the gearbox and wouldn't select any gears so i got it towed to a Transmission place. Blah Blah Blah. Got told the "Oil Pump in Transmission has blown up".
Question time:
1. Stagea gearbox is different to all other Nissan boxes being that its AWD RB25DET Neo?
2. Anyone know the Oil Pump Part No# for the Transmission?
3. Do you think you can get an after market one of these if so, where from?
Cheers,
Corey
https://www.sau.com.au/forums/topic/210419-gearbox-issues/
Hey guys,
Question time:
Cheers,
Corey
TRY WA Automatics on 94936080 ask for steve,good luck,only series 2 are different ,series 1 has A box most skylines,series 2 has B box tiptronic,cheer`s chuckie.
https://www.sau.com.au/forums/topic/210419-gearbox-issues/#findComment-3721451
the car is currently at a workshop in osbourne park, and cant find this damn oil pump info anywhere :domokun: ohhh and yeah its a 1998 Series 2 Stag with Tiptronic Box
Edited by BunkyS13
https://www.sau.com.au/forums/topic/210419-gearbox-issues/#findComment-3721476
what figures they quoting for rebuild ????
https://www.sau.com.au/forums/topic/210419-gearbox-issues/#findComment-3721553
well ive had a few updates....parts $920 ex. japan (nissan said could take upto 8 weeks to get here) so im just grabbing a gbox from a guy i know. waiting to hear back from the warranty company for them to say they will pay the Remove and Refit costs. only catch is because its a 2nd hand box they remove just the gbox from the warranty and the rest stays.
Cheers,
Corey
https://www.sau.com.au/forums/topic/210419-gearbox-issues/#findComment-3730287
Try Mike at MV Automatics is SA, he knows Nissan boxes better than anyone.
As far as I know all Nissan RWD autos are pretty much the same, minor variences only. R33GTST, R34GTT, Navara, Patrol etc
The ATTESSA doesn't make any difference to the internals of the auto, just the output shaft is different to accommodate the chain drive to the clutch pack.
Cheers
Gary
https://www.sau.com.au/forums/topic/210419-gearbox-issues/#findComment-3730787
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
