hehe my car was doin 895km/hr at Melbourne Autosalon :D
here's a few grabs from the initial modding stages ;)
1st record speed was 1071km/hr but it won't display for some reason (hence why its all blanks on mine)
hahaha... what a cheat... can you imagine your heart beat drifting at 696 km/h .... POP lol...
I think I have pulled 480 km/h in a 300zx...
512-520 km in a Jaguar XJ220
It was a while ago, so can't remember...
It took me about 3 hours playing with the gearing and NO CHEATS lol...
Guest skylineneeder
well i have my gearing sey the highest they will go and go in to the turn full throttle and keep goin until right before the you are going to tap the e-brake once then let go and you go off the wall just keep trying it will tak a whileif you want to do it the easy way just use the flying trick :burnout:
  • 3 weeks later...
front wing set to lowest
rear wing set to highest
drop the suspension height of the car to the max
spring and damper rates to the utmost minimum
set the gear ratios to the widest
switch off traction control and any other electronics
go flat out on Test Course track
CAR WILL EXCEED 1000KPH ON TWO WHEELS!
Feedback Please
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
    • 😜 hopefully we get this instead of a new R36 GTR due to recent financial problems at Nissan. Nismo to sell a complete kit with RB26 and driveline. All starts making sense (ok maybe not) once the Nissan Leaf's (Leaves?) with stuffed EV motors/batteries hit the market cheap
    • Hi guys , have had allot of time for SAU and has helped me out heaps in the past so I thought I would give it a go , I have my QM1 white NUR for sale 1 of 156 examples built by Nissan. Serious personal messages please if interested and details will be provided , asking 500k
