hehe my car was doin 895km/hr at Melbourne Autosalon :D
here's a few grabs from the initial modding stages ;)
1st record speed was 1071km/hr but it won't display for some reason (hence why its all blanks on mine)
hahaha... what a cheat... can you imagine your heart beat drifting at 696 km/h .... POP lol...
I think I have pulled 480 km/h in a 300zx...
512-520 km in a Jaguar XJ220
It was a while ago, so can't remember...
It took me about 3 hours playing with the gearing and NO CHEATS lol...
Guest skylineneeder
well i have my gearing sey the highest they will go and go in to the turn full throttle and keep goin until right before the you are going to tap the e-brake once then let go and you go off the wall just keep trying it will tak a whileif you want to do it the easy way just use the flying trick :burnout:
  • 3 weeks later...
front wing set to lowest
rear wing set to highest
drop the suspension height of the car to the max
spring and damper rates to the utmost minimum
set the gear ratios to the widest
switch off traction control and any other electronics
go flat out on Test Course track
CAR WILL EXCEED 1000KPH ON TWO WHEELS!
Feedback Please
    • Hello,   My name if Frederick, i'm 30 years old and I live in Belgium, Europe! I used to have a Nissan 370z daily but since I got a company car I turned that into my seattime driftcar. About 3 years ago I also wanted something older with more feel, so I got an R32 GTST with an rb26 engine. I am now getting the rb built to have around 800hp and it's close to being finished. I'm very excited for how it will drive and how driveable it will be! Regards, Fred!
    • Appreciate the insight! Talked to some local folks and they basically told me "it's not that deep." As long as the threading on the inside matches what's at the steering rack, everything else can be constructed-to-fit. There are full aftermarket kits I can use - probably better for my car overall since it's lowered.  Example: GKTech M14 Super Adjustable Inner Tie Rod Set - Nissan Skyline R32 R33 R33, 240SX, 300ZX, 350Z / Infiniti G35 M14I-TROD-2 gktM145-TROD gktM14I-TROD - Concept Z Performance (These can be packaged with their "high misalignment" tie rod ends).
    • Hey Mate , I suggest doing a search on eBay , they have a few kits that fit Q50 and might fit with a few modifications on a 400r.
    • Yeah so that clutch kit i post above would work and i do not need to worry? 🙂 https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type   This one.
