car will do around 250km to a full tank
mods
front mount cooler
r34 gtr fuel pump
car runs 10psi
stock computer
what is my problem and what should be normal full economy for a r33 running ten psi ?
anyone think the gtr full pump is not needed and to take it out??
Edited by rich flavour
https://www.sau.com.au/forums/topic/210487-r33-bad-fuel-economy/
  • Replies 74
Posted Images
Well i dont flog it but i guess if i drive off boost it would be better but i dont always drive on boost so it should be better then what it is
there is something wrong i get 350-400km out of a tank with 251rwkw @ 16psi (i boost it abit too) with ebc turn off (runs around 9psi) i can get upto 400-450km out of a tank
get an ecu and tune it
or use a piggyback
what are the advantages off piggy backing the ecu sorry for the silly question but i dont really know that much still learning any way heres a example:
i have a automatic Rb25det four door, 3" exhaust all the way thru coughcough no cat,FMIC,huge K&N pod filter,CAI + DIY heat shield for pod,runnin 7psi,split fire coil pack's and some
other stuff.
with the IMPUL r33 automatic ecu so if i take this out and use microtech LT10s ecu instead i will lose my shift points for automatic and aircon etc something like that anyway
so if i piggy back it with standard impul ecu i will still retain aircon and that?
will it be better that standard? any more info would be great before i go ahed with it guess it will help my fuel econ stop it from runing rich my mechanic said its runnin rich because im
pushing the limit on the IMPUL R33 Automatic ECU because the car can breath so much more air because off the stage1 mods i have noticed that it does not like to go to 10 psi hits
R & R so i left it at 7psi no flat spots aka lag so if i piggy back the IMPUL ecu with the aftermarket ecu then i should be able to sort out my A/F ratios etc.?
If you dont Know off the impul ecu here's a site that will let you know what it does ==> ==>"ABOUT THE IMPUL ECU click me" <== <==
here's the the type off car i got my ecu off
(actually it was SAU member i bought it off lucky if you can find one off these here's the link : ==> ==>"THE CAR THE ECU CAME FROM click me" <== <==
Cheers
Allan.M
Have to agree with paul, it is his ecu. If the car was stock then maybe not, but the ecu he has is not the ecu for the mods he has, esp. front mount and 10psi [how'd you measure this]. I had the same probs, and swapped for a pfc. I reckon the pfc has paid for itself in fuel saved and also gave a much better cleaner power delivery.
Plus, is his ecu stock? In a lot of jap imports the ecu chips are swapped out for no speed limiter/richer fuel units.
Have you popped the cover on your ecu and had a look at the chip etc?
yeh well i havnt checked the ecu for a chip.where could i get a test down so they can single out my problem? also where is the best place to get a pfc or im thinking of running a computer that dont use a afm...
i get 250km~ to a tank and backfire like a motherbollockser, and all ive done is a catback exhaust!
I think its time to check my o2 sensor too, the plugs are relatively new and i just gapped them to .8 but popping didnt change at all.
your an idiot if your warming your car up for 10mins each morning..get in start it idle it for 30secs-1min then drive it just baby it until thermostat opens and yeah...
ive got after market ecu LINK and its got a shit tune and i barely see 180kms per $60 around town and 250kms on highway so think yourself lucky.
time for a decent tune from a brisbane workshop:)
idling doesnt use that much fuel, obviously a bit more from a cold start but not enough to effect your economy that much, unless you only drive very short trips between cold starts.
you dont need to warm your car up for that much anyway, let it idle for 20-30 secs to build up oil pressure then just drive it soft to warm up everything, gearbox diff etc, not just the motor
how does this solve his problem?
what is the point of tring to fix the problem, if you don't know what the problem is. the problem isn't his ecu. and saying it is, is complete bs...
hi michael
whilst i usually avoid cross forum member attacks etc but anyway - given his list of mods and typical fuel economy most GTST guys see
i still think that its his ECU at fault, no where its a case of it just needs a decent tune, a sensor is toast, someone's remapped it to homo settings, or he has a non-supported 02 snsor etc
it could be many many things, but overall one of the essential fucntions of the ECU is fuel injection control and part of that is 02 feedback, which in turn gives you decent fuel economy 300kms+ to a tank.
short of wierd things such as split fuel hoses, loose fuel pumps, wierd filling up tank procedures (ie: him saying a full tank is really 30 liters instead of 50) then i suspect the ECU and tune is the next likely culprit. the recommended action would be to remap it, piggyback it, or change the ecu. if he isnt prepared to do then its needs more debuggin work on the dyno and on the street with a wideband sensor, which just wastes time and $. and besides he will make more power & response with either a remap, piggyback or standalone anyway
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
    • I might have gone a little more South Efrican.  But this is off topic.   😍😍 FD 😍😍
