Does anyone know of a company that makes a oil filter block plate for the RB26?
I've searched around and havn't found any company that makes this, only oil filter relocation kits that bolt straight onto the warmer/cooler.
I want to run the lines straight out from the block to the filter/cooler.
starting to wonder why there arnt many companies making these for the rb26, maybe its not a good idea?? cant see any problem with it apart from the loss of the oil warmer and having to wait a little more time to let the oil warm up before driving...
I'm after a plate exactly like this one, made by Tomei for the SR20, but I'm obviously after one for rb26.. thanks
thanks guys for the info, I've got an aftermarket oil cooler and a oil filter relocation kit already.
I'm really just wanting to get rid of all of this and replace it with a plate on the block, then run the lines straight from that to the filter relocation plate / after market oil cooler.
Edited by CameronBNR32
I presume you mean like this RB26 in the photo below -
http://i175.photobucket.com/albums/w129/r2...6Buildup057.jpg
Thread adaptor for short block -
http://i175.photobucket.com/albums/w129/r2...6Buildup056.jpg
The above sandwich plate is a Mocal sandwich plate with a thread adaptor for the short block. I noticed it cost's roughly $20 USD
for the thread adaptor and $90 USD for the Mocal sandwich plate.
Oil relocation kit fits on top of sandwich plate, where oil filter goes on the sandwich plate and the lines from
side of sandwich plate go to oil cooler core.
Oil filter on top of sandwich plate -
http://i175.photobucket.com/albums/w129/r2...6Buildup058.jpg
Another way (I presume the way you want to do it) is to mount the Permacool (or Mocal) remote take off to the short block in place of the Mocal sandwich plate,
then run lines to remote filter plate. Then fit sandwich plate to where oilfilter goes on remote filter plate. Then oil lines from
side of sandwich plate to oil cooler core -
http://www.trackscotland.co.uk/images/cooooler.jpg
Edited by SKYPER
Hey, thanks all for all the great info!
I think I'll get the oil cooler adaptor type b from greddy http://www.trust-power.com/spec_swf/04cool...RepairParts.swf Has the sensor fittings that I need, but not sure on what thread or pitch yet :no:
I'm going to pull off all the stock oil cooler and see what I have to do to mount it there.... Does anyone know if I have to drill/tap a fitting in there? or does it already have a thread/fitting there?
Will see when I pull it all off I guess....
GeeTR: my car is more of a track car than street, I hardly ever drive it and when I do I warm it up before driving it anywhere.
There is a fitting already there thats o ringed to seal.
Ive used the trust ones from high octane, and also a factory one I modified on my own GTR.
Simplifies the water lines under the plenum somewhat which always makes it easier to work on.
Mate i have just done this mod to my R32 GTR i got a really well made (CNC) remote filter mount. You have to be careful of the diameter of the remote filter mount no more than 70mm or its to large to fit.
The factory oil water cooler will pull off after you remove the 4 mounting bolts / studs then you will be left with a fitting to suit the slide on factory oil water cooler. This you can remove by vice grips or such as it round with no flats to get a spanner on. this will leave you with a 20 x 1.5 thread which most sandwich plates or remote filter housing send with the kit.
I got this from Ebay and if your interested drop me a PM and i will give you the sellers details.
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
    • STOP GOOGLING FAB9 MAKE BORG WARNER EFR KITS FOR THE NC. THEY PACKAGE AN EFR 6758. DO NOTHING ELSE. CAPS INTENTIONAL. THE BEST RESPONSIVE SETUP EXISTS FOR YOUR CAR, AND HAS BEEN PROVEN FOR QUITE SOME TIME NOW. IN B4 "BUT I WANT EVEN MORE RESPONSE, IN A SIMPLER, MORE RELIABLE PACKAGE" WHICH IS A LS.
