hey guys,
anyone that has played this game if you could help me out it would be great.
im up to the point where the Chunin exam final should be but there is no mission available (blue scroll) and all that i am able to do is the ninja races and hide and seek.
does anyone know where i have to go or what i have done wrong.
thakns
https://www.sau.com.au/forums/topic/210515-naruto-rise-of-the-ninja/
hey guys,
thakns
Only Just started Naruto: RoN, so im not up to this bit yet, but check out www.gamefaqs.com if you havent already...
ummm its not bad... the downloadable Japanese Voices is an awesome idea and a huge plus for me, as im a fan of the original Japanese VA's...
Otherwise, the fighting isnt bad, i dont use many combos but they are there to use... not sure if you can make your own...
Story is short, they try to intergrate the anime into the game as movie sequences... i think its a bit half assed but others may disagree... i think they couldve worked on the translations from Japanese to English a bit better...
The cel-shaded graphics are smooth and well done.
It can get a bit repetative at times doing random missions for villagers... and doing the blue scroll missions (Story Missions) is pretty short...
id probably rate it a (being generous) 7/10
For an awesome video review check out GameTrailers Review (In HD):
http://www.gametrailers.com/player/27752.html
    • Coming home late at night and driving past the police is the only reason i need one haha And yeh, definitley needs a switch to quickly enable it, dont have time to be getting my phone, opening an app, waiting for it to update etc before being able to make the change
    • Because it is financially convenient for them lol. Why wouldn't they want to give you the lowest possible valuation for your car?
    • Yep. @Duncan also shannons they will rip you dry and will be probably limited on how much you can drive. Also keep in mind that you always have to have it garaged with Shannons, with enthusiasts as per their PDS you can have it 2 times per week on the driveway for example.
    • I had a generic 4" Varex rear box on my old V8, worked a treat for sneaking home late at night, it was as quite as stock when closed The car was "fairly" loud when open as it consisted of 1" 7/8 headers to 3" catted Y pipe, to 4" single, it did have a resonator in the mid pipe and only the Varex out the back I also hard wired in a Varex dash mount switch, as the key fob thing is a pain to use when driving I wouldn't recommend giving the beans when it is closed though as it creates a large restriction in the exhaust  It also can in very handy when pulled over for "random" breath tests or just cruising past the constabulary
    • Here is the before and after of the scraping/sanding of the IC pads on the tachometer board for the fix mentioned in this thread. And yes it worked fine after. Just a note if you change any components on the board the tach calibration can be wrong showing the wrong idle etc...only problem is once it is installed back in the cluster you can't get to it to adjust...ouch! My fix was to cut out the calibration pot (the blue one) from the board and run it with two wires to the fuse panel under the dash where I could adjust the idle calibration once everything was installed. And yes I soldered everything up again including the half soldered components either side of the IC in my photos
