Also spotted EMSTA tonight parked around the corner from my place in Lakeside Pakenham.
woo yeah - another one! was working a bit late tonight. left at around 7pm ish. The townhouse that it was parked in front of is part of our office (only till may though)
Seen that around a few times... isnt there someone on here with that as a userid?
Pretty sure its a chick...
EDIT::
oh here ya go
http://www.skylinesaustralia.com/forums/m16407.html
Spotted a White R33 - at roughly 12:15am passing Shell on Princes Highway, Hallam.
I was pulling a u-turn in a truck so I couldn't really have a proper look..
lies!!! just pull the e-brake and do the scandanavian flick - that should do the trick
lol, it's kinda hard to pull the e-brake since it's air brakes and not a proper e-brake that you just pull up..
Spotted a very clean white R33 GTS-T driving down Spencer St from Dynon Rd towards city at around 1830 today.
Stood out, must have been a girl's car. Had hot pink plates and huge hot pink "NISMO" scrawled across the sides. Was driving too fast to notice her plates :(
Spotted a Blue 34 turning right from Princess Hwy onto Westall Rd at the same time a White 34 was turning left off Westall Rd onto Princess Hwy at around 7:45am... ...Blue had SAU stickers (UKBxxx)...
A few min later on heatherton spotted a silver 34 turned off Springvale Rd and then into Olympic Ave...
Then on the way home spotted a White 33 that changed lanes in front of me a little close to my bumper... ...(UFIxxx I think)...
Also at some point saw a white 32... ...lots of black and brown around the zorst...
Emsta knows nothing about drucks :banana:
At least you can admit it! :banana:
Probably making sure that you notice him/her.. lol :/
    • Don't do it if your gearbox box has already having syncro issues. The short hifter will put a greater load on them. If you must I remember Nismo did a shorter shifter, with the top part being physically shorter and the part that went into the gearbox was the same as stock. In saying that I've had a C's short shifter (I think) in mine for many years, which was given to me as the previous owner was not sympathetic to the gearbox. Thus forwarned I was careful and had to modify my normal changing style. You have to be super accurate with your clutch and shifts
    • Well, after a week of daily driving and having to crawl out between the wheel and the side intrusion bars. I got myself a quick release setup. I went with an NRG short hub and Quick Release with some cute heart cutouts on the pull tabs. Nice and matchy matchy with the rest of the interior accents I have going on.  The only downside is the total stack height even with the short adapter is longer than the old HKB boss kit. Luckily I had some adjustment left on the column so move the wheel away.
    • stock shifter with new bushes, springs and cup will improve it. Gktech do all the bits. The opinion as the years have gone on is the redline is not great in old gearboxes.
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
