Also spotted EMSTA tonight parked around the corner from my place in Lakeside Pakenham.
woo yeah - another one! was working a bit late tonight. left at around 7pm ish. The townhouse that it was parked in front of is part of our office (only till may though)
Seen that around a few times... isnt there someone on here with that as a userid?
Pretty sure its a chick...
EDIT::
oh here ya go
http://www.skylinesaustralia.com/forums/m16407.html
Spotted a White R33 - at roughly 12:15am passing Shell on Princes Highway, Hallam.
I was pulling a u-turn in a truck so I couldn't really have a proper look..
lies!!! just pull the e-brake and do the scandanavian flick - that should do the trick
lol, it's kinda hard to pull the e-brake since it's air brakes and not a proper e-brake that you just pull up..
Spotted a very clean white R33 GTS-T driving down Spencer St from Dynon Rd towards city at around 1830 today.
Stood out, must have been a girl's car. Had hot pink plates and huge hot pink "NISMO" scrawled across the sides. Was driving too fast to notice her plates :(
Spotted a Blue 34 turning right from Princess Hwy onto Westall Rd at the same time a White 34 was turning left off Westall Rd onto Princess Hwy at around 7:45am... ...Blue had SAU stickers (UKBxxx)...
A few min later on heatherton spotted a silver 34 turned off Springvale Rd and then into Olympic Ave...
Then on the way home spotted a White 33 that changed lanes in front of me a little close to my bumper... ...(UFIxxx I think)...
Also at some point saw a white 32... ...lots of black and brown around the zorst...
Emsta knows nothing about drucks :banana:
At least you can admit it! :banana:
Probably making sure that you notice him/her.. lol :/
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
