thatll be James
Crazy_J on the forums
i had my car as the bridal car at he's wedding :laugh:
ahk seen him the other night... never seen him before
theres another maroon 32 with black bonnet in melton that i see and i seen a black 34 for the first time aswell
saw a grey 33 on princes hwy in hallam and then he was behind me till fountain gate then dunno where he was.
also saw a r32 turn out onto princes hwy near nitro gym as i was waiting to do a u turn.
hey what color and what time because i came from HP from gf place slept over and got onto princess this morning to get to my pre apprenticeship this morning just got on time thought was running bit late, that could of been me the 32
Edited by BRUNSKIGTST
Just cruised down toorak rd/burwood hwy in my r32 to get some tyres fitted
Spotted:
B3ZA on burwood hwy near the BP
Black r32 with red/black advans and bomex front bar on toorak rd near tooronga rd - thought u were Karl, but he said he gave u the bar and rims :P
Another black r34 on burwood hwy near beaurepairs, didnt look my way.
Saw a black R33 at the Caroline Springs Carwash. RIght next to the CS Maccas and Petrol Station.
He pulled in booth nex to me, but didnt hav Sau sticker so wasnt sure if he is on SAU.
hey i think that was me. Was it about a week ago? cause last time i went there i dident see no skyline ... anyways hope to see you there agian next time we will chat
Spotted:
Black r32 with red/black advans and bomex front bar on toorak rd near tooronga rd - thought u were Karl, but he said he gave u the bar and rims :)
hey! i saw you and the 2 cars you saw aswell lol was on way home from uni!
tried catching upto you after it turned green for me but couldnt find you haha
i seen that black R34 few times on that road aswell.
Haha yeh I pulled into beaurepairs to pick up some wheels.
FINALLY SOMEONE SAW MY CARRRRRRRRRRRRRRRRRRR Yay :)
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
