Spotted Thread
paulr33
Oh and I saw a nice silver R33 GTR today in the emergency lane on the side of westgate freeway near power street exit just before you go into the tunnel heading onto the Monash. I tooted but couldn't stop to see if you were ok because I was mega late for work. Was about 9:45am
not too close now or you'll be eating flames and gravel hahaha!!
I'm off James cook drive so no doubt you'll catch me sooner or later. I'll keep an eye out. Heaps of dickheads on JC Drive too, mostly come from that house with all the Commonwhores sitting out the front! and NONE of them can drive for shit!
Beauty of living in Melton is, you go on the freeway on-ramp from the driving range heading to baccus marsh and you can almost hit redline in 2nd without breaking the speed limit! I love 110 zones
If the guys you're talking about are opposite a court, that's my mrs court, and yeah they're bunch of derro hoons lol my mrs knows some of them. It's just after James cook milkbar?
Yeah mate that's them. I am off herritage way a bit further up from there.
saw a nice white R32 GTR with SAU stickers driving on mahoneys road at around 3:30 today as i was about to cross the road
pulled into the united fuel station
if your reading this, dont talk on the phone while driving!
i was about to wave but thought naww ill look like a retard waving at the minivan thats about to pass me
Spotted Gunmetal gray 32 GTST with SAU stickers @ BP Towerhill (on Frankston-Hastings Rd or Moorooduc Hwy)
Also Silver 33 GTST @ Warrigal Rd - If you're reading this, fix the left headlight.
Cheers
Grant
Headlight fixed. It sucks that you can't buy single Phillips diamond vision globes. Another $90 bucks I had to fork out.
Edited by Swink33
drove past a Yellow r34 GTT with no spoiler on Corrigan rd
was gonna flash but there xenon's were to bright couldnt tell what car it was till they went past, so i flashed with my rear fog light insted hehe
i was in the stagea
i think the car you're talkin about has YPERV4 number plates
    • hello everyone, an RB26, or RB25 project in the medium long term. I don't know much about this engine or turbo engines in general, I'm here to understand and gain knowledge. I have specific objectives for a project
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
