Drag race Orange Yellow Guidaro vs Gunmetal Vanquish. 840am Melb cup day from lights heading north under Richmond station up towards Bridge Rd. Guiardo was winning by a car length before MCG carpark. If I only had a fast to start up camera...
nice looking 33 gtst s2 with white rims today...
also 2 red gtt's about 4 33's and a guy in a black 32 that tried to race me on punt road, on cup day.... not a great idea :D
i've seen that pink vlt around too... :D
hahaha yeah i see that guy around quite frequently. its a NA Turbo. not exactly my style but each to their own.
saw him again at delahey maccas a few nights ago with his unbelievable bright pink neons. hmmmmm
Edited by PSI.33
Just back from a long weekend... Spotted lots of Skylines..
Saturday..
Dark/blue 33 in the morning on the westgate, SAU stickers, I gave you a wave.
A white 33 at the start of the great ocean road in Torquay.
A blue 34 GT-R in Apollo Bay.
Sunday..
White 33 GT-R on the road between Dunkeld and Halls Gap in the Grampians
Monday..
A grey 34 4 door in Ballarat.
A white 33 GTS-T in the car park at the Novatel resort at Creswick.
i've seen that pink vlt around too... :huh:
Saw that vl turbo on friday night on kings road outside delahey maccas... and saw a yellow one on main road east in st albans
Spotted a white 33 parked near Subway at Knox today - had SAU stickers and green P's
HI!!
Thats Leigh! (4door_33gts) he works at pizza hut next to subway, go get a free pizza next time! :laughing-smiley-014:
Edited by b3za
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
