Saw a marroon/red Series 1 Stag on Camberwell Rd heading towards the junction Wednesday around 4:30-5:00pm, flashed my foggies, got a wave back. I like the colour coded roof racks, finishes the car.
I actually see this one just about every morning, must work at Toyota or something near by.
Also saw black R34 Coupe last night at Nunawading Basketlball stadium around 7pm whilst walking my dog, very clean looking from where I was, black rims with chrome lip, looks very nice.
On the same walk about 10mins later saw a white R33 hang it out from Gyton Ave into Highbury road, hitting boost limiter or rev cut, lot of tyre noise/bitumen grinding sound.....but you didnt load it up enough, not one bit of rubber or smoke :( ...... I was hoping something :(
Black r33 'JUST8U' driving though dandenong on lonsdale st, i was behind that calais that was like a magnet on you.
Black r33 behind me at the same time QIK330 (sneaky) sorry if i frustraited you dude, was in granny mode :P
Black r33 at a red light on Cheltenham road and springvale road, black rims and silver lip around 11pm-ish
saw a black 33 tonight around 10 - 10-30, was waiting to turn right at the lights near either carrum on bonbeach station..was a mickey mouse 33 bro all done up looks mean az thought i was a s15 for a second but had to re look and saw it...was in the silver 33
day before spotted RBPOWER driving past me on hallam rd gave ya the thumbs up :P
haha thumbs up ? geez thought was gonna try grab my car lol, whole arm flew out of the car.
i forgot your online SAU tag name, so didnt do the spot
come on matty dont be like that ....
saw a Black r34 4door with SAU stickers up on a ramp in a CARYARD!
Cheltenham road Dandenong across the road from the shell service station $11,990
Thats Ash's car.. he sold it for a mitsubishi! :)
spotted a few days ago at montrose gtxr34 white thing I saw the sau stickers..you were parked behind my car the black xr6t...pretty sure ya saw me perving at your car... also who was in the blue r32 heading up mt.dandedong road at around 7 this morning I was in the xr6 again..had a lil run with you...
    • Haha yea it's a bit of a weird setup at the moment, just wanted to make sure I sorted out any headaches before dyno day. At the moment I've changed the exhaust manifold, turbo and downpipe, 460lph fuel pump and rising rate reg as well as the previously mentioned headstuds and gasket. The nistune was already mapped for the car as it was and drove around for a few months no worries. The plan is to run flex fuel hence the big pump, which I've wired direct to the battery through a relay to avoid voltage issues.
    • Um. Was the ECU the same as the one previously there? I know R33's needed R32 GTST ECU's or other tomfoolery to run Nistune. This is such a wild setup. Most people would plumb in the turbo then not drive the car (i.e tow it to a tuner). What's actually changed since it last ran?
    • I'm a bit stuck with this one fellas, I recently decided to undertake a turbo conversion on my GTS-4, ended up pulling the motor to replace all the seals and do an mls head gasket and arp head studs while I was at it. Everything has gone according to plan, no oil or coolant leaks, compression checked out, and decided to give it a test before I book it in for a tune As it stands right now, the turbo only has oil lines plumbed so that I don't put boost into my untuned engine, and I'm using the factory GTS-T crossover pipe with a maf and poddy as a temporary intake. The car starts with relative ease and idles amazingly, however as the title suggests it really doesn't want to rev up, runs very smooth but almost feels choked out and unresponsive to the throttle, almost like it's running lean or something? I've triple checked my vacuum lines and timing with a timing light, injectors haven't been touched as of yet to avoid flooding the engine and worked perfectly beforehand, new plugs and coilpacks, I've even unbolted the cat just to see if it spontaneously collapsed, no dice The car currently has a nistune r32 gtst ecu installed so I have no way to check for fault codes. At this point I'm a bit stumped. Is this normal behaviour for a car with a turbo bolted onto the exhaust going nowhere? I'd imagine the turbo wouldn't cause this much restriction in the exhaust without the boost going through the intake. Any ideas? If necessary I can link a video of how it responds to full throttle while in neutral.
    • Insert tab A into slot B?
    • Instructions seem simple enough to understand.....
